Latest post Thu, Jan 21 2021 3:49 PM by Vadym. 1 replies.
Page 1 of 1 (2 items)
  • Wed, Sep 23 2020 7:54 PM
    /UICore.js:1 Update is Children update state failed, Action will be disabled: Empty "text" property(avid.open.with.application - menu) TypeError: Cannot convert undefined or null to object
    my hamburger context menu for actions inside my app is not opening due to the error in the subject.
    but for my app I just define actions inside my
    export const avid = [
    // Search menu actions
    provides: ['actions'],
    create: () => SearchMenuActions,
    // Search action binding
    provides: ['actionBindings'],
    create: () => SearchMenuActionBindings,
    which point to these.
    export const SearchMenuActions = {
    text: 'Import to Interplay',
    handler: ({ selection, component })=> component.importAssets(),
    export const SearchMenuActionBindings = {
    places: ['contextMenu', 'viewMenu'],
    filter: ['mediator-search-view'],
    defaults: {
    index: 500,
    menuModelProvider: () => [{actionId: 'import-action', index: 500}],
    I'm not sure why the menu is throwing the exception in UICore.js?
    text_of_exception
    close @ webpack-internal:///./node_modules/webpack-dev-server/client/index.js?https://localhost:172
    :9000/plugins/core-app/plugins/com.avid.central.UICore/js/UICore.js:1 Update is Children update state failed, Action will be disabled:  Empty "text" property(avid.open.with.application - menu) TypeError: Cannot convert undefined or null to object
        at Function.keys (<anonymous>)
        at c (:9000/plugins/core-app/plugins/com.avid.central.UICore/js/UICore.js:1)
        at Object.getPreferredApp (:9000/plugins/core-app/plugins/com.avid.central.UICore/js/UICore.js:1)
        at r (:9000/plugins/core-app/plugins/com.avid.central.UICore/js/UICore.js:1)
        at Object.createItems (:9000/plugins/core-app/plugins/com.avid.central.UICore/js/UICore.js:1)
        at l.updateItemsIfDynamic (:9000/plugins/core-app/plugins/com.avid.central.UICore/js/UICore.js:1)
        at l.updateChildren (:9000/plugins/core-app/plugins/com.avid.central.UICore/js/UICore.js:1)
        at :9000/plugins/core-app/plugins/com.avid.central.UICore/js/UICore.js:1
        at async Promise.all (index 1)
    failUpdate @ :9000/plugins/core-app/plugins/com.avid.central.UICore/js/UICore.js:1
    webpack-internal:///./node_modules/webpack-dev-server/client/index.js?https://localhost:48 [WDS] Hot Module Replacement enabled.
    webpack-internal:///./node_modules/webpack-dev-server/client/index.js?https://localhost:52 [WDS] Live Reloading enabled.
    webpack-internal:///./node_modules/webpack-dev-server/client/utils/reloadApp.js:19 [WDS] App hot update...
    sockjs.js?9be2:1684 WebSocket connection to 'wss://localhost:9000/sockjs-node/134/4ui1f1ez/websocket' failed: Invalid frame header
    WebSocketBrowserDriver @ sockjs.js?9be2:1684
    webpack-internal:///./node_modules/webpack-dev-server/client/index.js?https://localhost:172 [WDS] Disconnected!
    Normal 0 false false false EN-US X-NONE X-NONE
  • Thu, Jan 21 2021 3:49 PM In reply to
    • Vadym
    • Joined on Thu, Apr 17 2014
    • Posts 262
    • Points 3,110
    • ! Avid Employee
    Re: /UICore.js:1 Update is Children update state failed, Action will be disabled: Empty "text" property(avid.open.with.application - menu) TypeError: Cannot convert undefined or null to object
    Hi Jeff,
    Could you show how your imports are done? This could be the issue with incorrect import/export.
    We have an example available for the actions API if you'd like to use it for your reference
    http://developer.avid.com/mcux_ui_plugin/clux-api/actions-api.html
    https://github.com/avid-technology/ui-toolkit-action-example
