Latest post Tue, Sep 29 2020 1:20 AM by jef. 9 replies.
Page 1 of 1 (10 items)
  • Fri, Sep 18 2020 3:13 PM
    • TaT
    • Posts 62
    • Points 760
    Advanced (Polyphase) image interpolation mode bug still present..
    This problem is a long time with us. Still unsolved...
    1080i50 project and UHD clips.
    FrameFlex gives strange results that depend on the selected image interpolation mode.
    ADVANCED gives a worse result than the STANDARD!
    Avid please do something with it...
    TaT
    Apple Mac Pro 2019, Intel Xeon W 3.2GHz 16 core, 192GB RAM, Radeon Pro Vega II 32GB, Avid MC 2020.9, OS 10.15.6 *** PC X99 mobo i7-5960X 8 core 4.3GHz... [view my complete system specs]
  • Fri, Sep 18 2020 7:26 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,788
    • Points 45,360
    Re: Advanced (Polyphase) image interpolation mode bug still present..
    Check and see if you have GPU render enabled under the Render Settings preference.  Try it with that disabled.
    Jef
    Jef Huey
  • Fri, Sep 18 2020 7:56 PM In reply to
    • TaT
    • Posts 62
    • Points 760
    Thx Jef for quick helping hand but when you show the complete image, you will see that I did it... Huh?
    TaT
    • TaT
    • Posts 62
    • Points 760
    Thx Jef for quick helping hand. I will try.
    TaT
  • Fri, Sep 18 2020 8:55 PM In reply to
    • TaT
    • Posts 62
    • Points 760
    It works! Smile But it's strange that Radeon Pro Vega II in my new Mac Pro can't be fully utilised in MC...
    Thx once again
    TaT
    EOT
    • TaT
    • Posts 62
    • Points 760
    Thx once again
    TaT
    EOT
  • Fri, Sep 18 2020 9:26 PM In reply to
    • jef
    • Maryland
    • Posts 3,788
    • Points 45,360
    My theory is that Advanced Polyphase was implimented before ANY gpu support and is an entirely software based approach.  Trying to dump certain tasks (scaling in this case) to the GPU is probably causing something in the GPU to conflict with the Software.
    But I am no programmer.  Just have been watching the software for a LONG time.
    Jef
    Jef Huey
  • Sat, Sep 19 2020 11:29 AM In reply to
    • TaT
    • Posts 62
    • Points 760
    My theory is that Avid programmers don't like Mac and Radeon gfx cards... only NVIDIA!
    FrameFlex with Advanced (Polyphase) image interpolation and ENABLED GPU effect works great with my Windows setup with the ancient GTX970 gfx card... I'm an ancient MC user too... Geeked
    TaT
  • Tue, Sep 29 2020 12:12 AM In reply to
    This burned me last week, too!
    I didn't want to run w/o GPU for downscaling 4k to HD, and the ONLY way to make it work w/o glitches was to switch the renderer to Standard (BiLinear).
    Yes, if I turn off GPU renderer it's also fine.
    Can we get an AVID response on this?? I'm sure Polyphase is better than Bilinear, but is it worth running w/o GPU render?
    TIA,
    Jason
    BTW: Mac (Hack) running 10.14.6 MC 2020.08 with Vega 64
    Hackintosh i9-9900K, AMD Radeon Vega 64, 64 GB RAM, m.2 SSD, 8x 10GigE to Terrablock, BM SDI 4k, currently running Mac OS 10.14.6. Ultimate 2020.09.0 [view my complete system specs]
  • Tue, Sep 29 2020 1:20 AM In reply to
    • jef
    • Maryland
    • Posts 3,788
    • Points 45,360
    Jason Sedmak:
    This could be a complicated issue.  The question is, if you are using a GPU for scaling, does it have an equivilant to Polyphase (whatever that means (don't get me started on marketing BS terms)?  Or is it just using what ever closest filter type is present on the GPU instruction set?  We do not know.
    I think this just points out the myriad issues that integrating GPUs into an established software based image processing system presents.  And we are stuck with the results.
    Personally I am running with GPU off for now (assuming I do not forget this when setting up a system).
    Jef
    Jef Huey
