Latest post Sat, Sep 19 2020 8:08 PM by mtahir. 5 replies.
Page 1 of 1 (6 items)
  • Mon, Sep 14 2020 10:46 PM
    • mtahir
    • UK
    • Posts 563
    • Points 6,915
    Effect of changing raster using Format tab
    It says in the timeline window that my project is 1080p/25. If I change it to 1080i/50 using the Format tab, what happens in terms of quality, rendering etc., or does the change only effect downstream hardware?
    I've got an Intensity Pro 4K connected with the S-Video outputs to my monitor and I can only get an output if change the raster to 25i PAL, 25p PAL or 1080i/50. My monitor is blank with the project set to 1080p/25.
    MC2024.10 (Win10) | DaVinci Resolve Studio | Dell T7500 with 2 x 6-Core Intel Xeon X5690 3.46GHz CPUs | Triple-Channel 96GB (48GB per CPU) 1333MHz DDR3... [view my complete system specs]
  • Tue, Sep 15 2020 9:43 AM In reply to
    Re: Effect of changing raster using Format tab
    It will only affect any rendered or created media. Its common to work in 25P as its makes DNx36 available for the offline work.
    If a 50i deliverable is required then the format is changed at the online and the effects titles etc re-rendered.
    T 07581 201248 | E [email protected]
  • Fri, Sep 18 2020 12:37 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,971
    • Points 70,590
    Did You try to fiddle with the output settings in the BM tool instead of changing the frame rate?
    Symphony 24.12, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro T400 [view my complete system specs]
    peace luca
  • Sat, Sep 19 2020 1:42 AM In reply to
    • mtahir
    • UK
    • Posts 563
    • Points 6,915
    Thanks for the replies.
    Yes, I did try the settings on the BM tool but they didn't seem to do anything. Even with the Matrox Mini (and that's in Windows 10), it will output a 1080p/25 timeline without having to switch to another frame rate.
  • Sat, Sep 19 2020 5:58 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,971
    • Points 70,590
    You have to run the tool from MC, if You set it outside MC will take over and apply its own settings.
    peace luca
  • Sat, Sep 19 2020 8:08 PM In reply to
    • mtahir
    • UK
    • Posts 563
    • Points 6,915
    I did run it from within MC. I'll give it another try. I'm currently re-building my Windows 10 partition.
