Latest post Tue, Oct 6 2020 3:54 PM by Michael Ray Brown. 5 replies.
Page 1 of 1 (6 items)
  • Mon, Aug 31 2020 2:18 PM
    AMA linked AVCHD files crash Media Composer 2020.8
    Since upgrading to version 2020.8, Avid now crashes when trying to play AMA linked AVCHD files in the source monitor.  I would like to downgrade to 2020.6, but that version is not listed in the Download Center.
    Michael
    Media Composer 2020.9 w/Symphony | OS X 10.15.7 | iMac 2017 (Retina 5K, 27-inch, 2017) 4.2 GHz Intel Core i7 | 40 GB 2400 MHz DDR4 | TerraMaster 16TB external... [view my complete system specs]
  • Mon, Aug 31 2020 3:33 PM In reply to
    • Posts 11,457
    • Points 234,105
    Re: AMA linked AVCHD files crash Media Composer 2020.8
    Michaal
    they are all listed - https://esd.avid.com/ProductDownload.aspx?id=2416 just not in numerical order.
    If you can provide your spcifications for the software and OS I can have a suport case created to assist you.
    Marisnna
  • Mon, Aug 31 2020 4:14 PM In reply to
    Marianna,
    Thanks for pointing out that MC version 2020.6 is still listed, and thanks for opening a case.  You can find my system specs in my post (below the signature).  While that earlier version is not officially supported on macOS Catalina 10.15.6, at least it did not crash with AVCHD.
    Michael
  • Tue, Oct 6 2020 5:35 AM In reply to
    Marianna,
    The release of a new version had me hoping this issue would be fixed.  But alas, MC 2020.9 still crashes with AVCHD media.  Can you tell me if a support case was opened?
    Michael
  • Tue, Oct 6 2020 12:26 PM In reply to
    • sergiumm
    • Joined on Mon, Dec 24 2012
    • Posts 83
    • Points 975
    Can you deselect all audio tracks of AVCHD clips and check again? To do this first unlink clips then Modify - Select Tracks and deselect all audio tracks.
    Media Composer 2020.6 MSI Z390-A PRO, Intel Core i7-8700, 24GB RAM 2400 MHz DDR4, Windows 10 64-bit, ASUS GeForce GTX 1060 [view my complete system specs]
  • Tue, Oct 6 2020 3:54 PM In reply to
    Yes, deselecting the audio tracks seems to work.  Simply importing AVCHD files also works without crashing version 2020.9 of MC.  Seems Avid is making progress.
