I used the Audio Punch-In tool to record some voice-overs. I then exported the audio to iZotope's RX6 for some processing. I then exported a .wav file from RX6.Is there a way to replace the Audio Punch-In audio with the audio from RX6?
http://dreamvalley.net
Actually, I just realised that the plugin is available within MC! For some reason, I just didn't see it. Anyway... let that be a lesson to you all!
I've discoverd that using the RX6 plugins within MC causes audio delays. No issue with using MC's built-in audio plugins. This is what iZotope say:
"Latency and Delay Compensation
iZotope plug-ins use complex DSP, which can create audible latency. During playback, this can result in a delay or offset to a single track's output, which can put a track out of sync with the rest of a mix.
Most modern audio applications include latency compensation and can automatically compensate for this offset, however, if you are noticing latency when working with iZotope plug-ins in your host, here are a few things to try:
