I'm trying to export as quicktime file a finished project (I have quicktime 7.79 installed) but when i tried to open it in VLC tell me that "AV1x" codec is not supported. Why? With 2019.x all was fine. The File is ok in Squeeze.
Ugo
Hi Ugo,
What is your goal? What kind of file do you want, and where will it be used?
What specific export settings are you using? In the 'Export As...' dialog box, if you click the 'Options' button, there is the drop-down menu with the old choice of 'QuickTime Movie', but there's a new choice 'MOV' at the bottom, which uses the new UME engine for export.
my goal is to save a copy in a mov format of the entire project and using "Quicktime movie" in "export as" menù and I have the error in VLC. I tried MOV end work fine.
You're welcome! I'm glad you found a solution.
