Latest post Sun, Aug 16 2020 4:39 PM by DStone. 4 replies.
  • Sat, Aug 15 2020 2:31 PM
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 323
    • Points 3,835
    i9 10900X vs i9 10920X - Advice on new computer build making a choice
    Been accumalting the parts - its been a problem getting compnents from the dealer I trust.  So I am wondering for video editing etc. will two more cores make a difference?
    From what I read MC is mostly single threaded?  Is that true?  From what I read speed is more important than cores - is that still relevant?
    i910900X is 3.7 gz
    i9 10920X is 3.5 gz
    So  wondering if there would be big difference the two.  I already have the procesor i9 10900X ordered but I can change it should i need to - I went with that one becasue it has higher gz speed.  But maybe 2ghz is not really that much higher.  I do plan plan to overclock slightly
    thank you
    Larry
    Symphony 2020.8 - Win 10 pro (1909),Gigabyte X299X with i9 10920X cpu, Quadro P2000, 64gig memory, 1TB NV ystem drive, WD 4TB, BM Min Monitor, 11.7 drivers... [view my complete system specs]
  • Sat, Aug 15 2020 4:52 PM In reply to
    • B3n3d1kt
    • Joined on Tue, Mar 24 2020
    • Germany
    • Posts 13
    • Points 130
    Re: i9 10900X vs i9 10920X - Advice on new computer build making a choice
    The clock speed (3,5 GHz; 3,7 GHz) is just the base clock. Like all current CPU this one has also boost setting.
    Here an overview with the boost clock of Cascade Lake X:
    https://en.wikipedia.org/wiki/Cascade_Lake_(microarchitecture)#Cascade_Lake-X_(Enthusiast)
    If you are really interested in, you find a lot of articles online about boosting (power limits, PL1, PL2, tau, problems, limits etc.).
    But in normal use the clock speed will be between the base and the boost clock. The clock depends on the settings and the conditions. If you have a good cooling solution (CPU, mainboard VRM) and modify some power settings the CPU will run at boost speed.
    MC 2019.12 (Win 10 1909) custom Workstation: AMD Threadripper 3960X (NH-U14S TR4-SP3 + NF-A15), ASUS TRX40-E Gaming, 64GB DDR4-3200 Corsair, MSI RTX 2070... [view my complete system specs]
  • Sat, Aug 15 2020 7:05 PM In reply to
    Go with more cores. 10 to 12 cores is a 20% increase. 3.5 to 3.7 is less than 7% increase.
    MC 2020.6, W10, Gigabyte X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 64GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012... [view my complete system specs]
  • Sun, Aug 16 2020 4:03 PM In reply to
    • LDV20
    • Posts 323
    • Points 3,835
    thank you both for the info - I am changing out the cpu - will just go for the 19 10920X
    L
  • Sun, Aug 16 2020 4:39 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,783
    • Points 48,355
      Moderator: MCA Mac
    Dom called that one correctly. While MC is not really multi-threaded in general, the one place it is mult-threaded is when doing transcodes and consolidates. So if you have to transcode media to DNxHR, this is the better solution. And I think that  (eventually) we'll see MC taking more advantage of multi-threaded processes (and I hope a lot more GPU processing).
    Dave S.
