Latest post Tue, Aug 4 2020 3:26 PM by Roger Owen. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Aug 4 2020 1:45 PM
    • Roger Owen
    • Joined on Wed, Jun 21 2006
    • The New Forest, South Coast, UK
    • Posts 119
    • Points 1,445
    Automatic linking of files.
    I'm still getting to grips with my massive upgrade from Xpress Pro to MC 2018.
    When I connect an external drive pretty well all files on that drive get linked to an open bin. Is there a way to prevent this, I just want to select certain files - and usually I like to import rather than link.
    Avid Media Composer 2018.11, Kona 3, HP XW8600 2x3.16 Ghz Quad Zeon (X5460), 8 Gb RAM, Windows 7 Pro 64 bit. Nvidia GeForce GTX 560 Ti. [view my complete system specs]
    Lots of kit... only one pair of hands!
  • Tue, Aug 4 2020 2:32 PM In reply to
    Re: Automatic linking of files.
    In project pane > Settings > Link > Volume mounting > untick Automatically Link to Volumes
    Andi
    HP ZBook G6 15 2.6Ghz 6-core i7 9th Gen Nvidia Quadro T2000 4GB 64GB RAM Win 10 Pro MC Ultimate 2018.12.11 MacbookPro 15 2019 6 core 2.6GHz i9... [view my complete system specs]
  • Tue, Aug 4 2020 2:59 PM In reply to
    Also, don't import. Use link, it is faster. Import also stops you from accessing the consolidate function which will slow things down even further.
    As a test I imported a 11.62GB (roughly 10 mins 30 secs in duration) AVC Intra MXF from a Canon C300mk2 to XDCAM 50 .
    Import took 4 mins 53 secs, Link and consolidate took 34 seconds.
    As a test of material that Avid cannot consolidate, I took an 895MB MP4 from a GoPro and imported/transcoded to DNx120
    Import took 4 min 15 secs and link and transcode took 49 secs
    Hopefully you can see the benefit of Link over import.  There are various other reasons to use link over import to do with frame rate, raster size, metadata etc so I would suggest having a bit of a dig around the forums for more info on this. Thre are very few reasons to use import any more.
    Andi
  • Tue, Aug 4 2020 3:19 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,722
    • Points 44,665
    Totally agree with Andi.  To add, the Import feature uses old tech that can lead to quality changes.  I really only use it these days for stills (jpg, png, etc.)
    Jef
    Jef Huey
  • Tue, Aug 4 2020 3:20 PM In reply to
    • Roger Owen
    • Posts 119
    • Points 1,445
    Thanks Andi, that's very helpfull. I have used 'Link' a few times and that was ok with MP4 files, but my kit is a bit old - HP XW8600 (USB 2 for external drives) and struggles with anything with a higher data rate. Thinking of getting an Esata card which should help.
  • Tue, Aug 4 2020 3:26 PM In reply to
    • Roger Owen
    • Posts 119
    • Points 1,445
    Thanks, I will need to update from USB2 to Esata. I've been using a small SSD with a sata to USB bridge for inputting (linking)  stills and JPEGs etc. but there's so much on the external drive and each time I plug it in Avid links everything that's on that drive rather letting me select what I want to link.
