I naturally have a bin of master and sub clips in Avid Media Composer tested in versions 2020/4/5/6 with Mojave 10.14.6 and a test machine with Catalina 10.15.5 with 2020.6 of Media Composer.Can't edit bin Metadata1. I typically make a custom column say TC Custom with-in my list view bin.
2. Properly enter my values into TC Custom column.
3. I naturally want to intentionally take the TC Custom data and paste it into the AUX TC2 column. I click on AUX TC2 and can't click anything or add any additional metadata to any fields.
4. I try duplicating/paste TC Custom to AUX TC2 I press Apple D to duplicate the column. I get a pop up box, but no option in the list for AUX TC2, also I click on the columns and they just highlight all grey, nothing can be edited after I have edited and intentionally added the custom column with my timecode values?
Leo
I'm having this issue on
2022.12.4
OS 12.6.6
Mac Studio M1 Max
Any text I type does not show up in bin columns. However if I view the same bin on the assistant system (PC) the text I have just typed in on the Mac system shows up on the PC.
Did you find a solution?
Cheers
ChrisH: I'm having this issue on 2022.12.4 OS 12.6.6 Mac Studio M1 Max Any text I type does not show up in bin columns. However if I view the same bin on the assistant system (PC) the text I have just typed in on the Mac system shows up on the PC. Did you find a solution? Cheers
Hi there
I would like to get. case going for this but I am not sure of your email address.... your email used for MyAvid at account.avid.com
Can you email me that info and this link so I can do that for you.
[email protected]
I`m also having the issue on a Mac Studio M2 Max with OS 13.4.1 and 2022.12.4
I can`t add or see metadata in custom columns on groups and timelines. The assistants on PCs can.
I will try installing a different avid version in the next days.
Best
Felix
That's a known issue in 22.12.4.
I rolled back to 22.12.3 and the issue was resolved.
Ok, thank you!
