Latest post Mon, Jul 13 2020 8:59 PM by Marianna. 3 replies.
  • Tue, Jul 7 2020 9:17 PM
    • jdrouette
    • Montréal, Canada
    • Posts 437
    • Points 5,725
    Docked panels stuck in 2020.6
    After updating to MC 2020.6, my custom dual-screen UI panel layout gets "stuck" in unusable positions every time I restart the software. Some panels appear to be partially hidden behind other panels even though none are floating, and I am not even able to select them to change them to floating mode (see the screen grab below and the TC window in the lower right).
    I tried creating a new user setting but get the same problem.
    Ideas?
    Thank you.
    Avid Media Composer 2020.8 Symphony option, Avid Artist DNxID (DNxID Desktop Video Application v11.5.1), macOS 10.15.6, iMac Pro (2017) 10-Core, 3.0GHz... [view my complete system specs]
  • Mon, Jul 13 2020 8:45 PM In reply to
    • Posts 11,317
    • Points 232,510
    Re: Docked panels stuck in 2020.6
    jd.....
    Let me ask support to look at this one.......  not an issue with 2020.6 but might have something to do qith 10.15.5 but let me see.....
    stand by for case to come into your inbox.
  • Mon, Jul 13 2020 8:52 PM In reply to
    • jdrouette
    • Montréal, Canada
    • Posts 437
    • Points 5,725
    Thanks again, Marianna.
    Will do.
    For what it's worth, I reverted back to MC 2020.5 and this issue disappeared.
  • Mon, Jul 13 2020 8:59 PM In reply to
    • Posts 11,317
    • Points 232,510
    jdrouette:
    Will do.
    Good thing you mentioned that one as I put that in the case notes that prior to 2020.6 ( 2020.5 and lower ) didnt have the issue.
    Big Smile
    Case # 03982312
