Latest post Mon, Jun 22 2020 12:19 PM by tgzb. 3 replies.
  • Mon, Jun 15 2020 6:54 AM
    • tgzb
    • Joined on Wed, Apr 23 2014
    • Posts 38
    • Points 550
    Serious problem, Assertion failed
    Suddenly, after not being able to export a sequence, Avid MC stopped working properly.
    After booting the application, when I open a project I get the following error message:
    assersion failed: m_valid File:/Builds/workspace/MC/Release_installer_Git/Mac_Build/coresw/VolumeUI/volMenuUtils.c Line: 1089
    then I can choose from debugger, continue, exit applictaion or create report, but I can't work. if I choose continue, I'll get this message on everything I try to do.
    It happens in all my projects, including a newly creatd one.
    I tried the following:
    Restart the computer
    uninstall and install Avid MC again
    Deleting the latest render files, thought maybe they caused the problem.
    but the problem persists. Please help! I can't work!
    iMac Pro 2017
    OSX Mojave 10.14.6
    Avid MC 2020.5
  • Mon, Jun 15 2020 7:59 AM In reply to
    • tgzb
    • Posts 38
    • Points 550
    Re: Serious problem, Assertion failed
    Okay, after many more trials, I found out that if I remove one of the Raids I'm working with, the problen's gone. But what if I need to work on footage on that Raid?
  • Thu, Jun 18 2020 7:37 AM In reply to
    Hello,
    Have you tried to delete the pmr and mdb database on this raid volume?
    https://avid.secure.force.com/pkb/articles/en_US/troubleshooting/en366151
    This will cause the Media Composer to rescan your volume and recreate new, and hopefully uncorrupted metadata. You have to do this in each folders within the MXF folder.
    Regards,
    Benoît.
  • Mon, Jun 22 2020 12:19 PM In reply to
    • tgzb
    • Posts 38
    • Points 550
    I tried it, ant it worked.Thanks.
    I'm still having the problem if I attach a hard drive while Avid MC in on, even if that drive doesn't hane an Avid MediaFiles folder in it.
