Latest post Wed, Jun 10 2020 12:55 PM by Pat Horridge. 2 replies.
  • Wed, Jun 10 2020 7:18 AM
    • adamsonn
    • South Africa
    • Posts 695
    • Points 10,330
    Transcode / Import / Render format - which is optimal
    Hi
    Prior to MC 2020 I would transcode / import / render and edit in DNXHD 120 - I see that the default is AVC Intra 100.
    There are a lot of other options as well.
    While DNXHD served me well -  I havent had any issues related to AVC INtra either.
    But my output formats are not rigidly defined  so maybe I am not best positioned to evaluate this.
    Being consistent across an entire project I imagine is preferable but is there an optimal format as well  that is recommended ?
    Any comments here?
    I am trending towards DNXhd SQ but would be interested in other experiences
    Neil
    MC6 machine: Intel Core i7 Asus P8-H67 64 bit Motherboard 1*1Tb SATA drive - partitioned to C (OS and programs) and D (data) drive 1*1TB SATA drive... [view my complete system specs]
  • Wed, Jun 10 2020 8:21 AM In reply to
    Re: Transcode / Import / Render format - which is optimal
    I doubt that AVCIntra is standard. Did you create new user settings? The DNxHD family has been renamed. What was called 120 is now called SQ. I would see little reason to switch from that. AVCIntra is meant for specific (Panasonic) workflows, that use it end-to-end, AFAIK.
  • Wed, Jun 10 2020 12:55 PM In reply to
    I'd avoid AVC Intra unless you specifically need for an end to end workflow or to deliver DPP files (as a mixdown stage to AVC Intra) its a low datarate codec relatively but processor demanding so you will see a perfomance hit.
