Latest post Thu, Jun 25 2020 8:25 PM by Marianna. 3 replies.
  • Fri, Jun 5 2020 9:41 PM
    • Joel
    • Joined on Fri, Dec 14 2007
    • Los Angeles
    • Posts 12
    • Points 160
    Applying Quick Transition Causes Crash/Unresponsiveness
    I just got a 2019 Macbook Pro 16" and was trying out MC 2020.5.0 on OSX 10.15.4. For the most part it's running great, but I noticed that every time I add a quick transition it causes the whole interface to choke. I am unable to start playback at any point within the sequence, even though I can move the BPI. I've messed with this a bit, and even after removing the transition I'm unable to work so I close and restart Avid. Once the process of reopening Avid begins I will normally have a crash. Opening it a second time works though. If the transition is still applied then I will have to option open the project, otherwise it will crash.
    My sequence has a few dissolves in it so I've been able to save those to a bin and apply them that way, which doesn't cause any issues, but this seems like a pretty big issue. I don't believe it has anything to do with my configuration, this is a brand new computer and I have very little additional software on it.
    Anyone else experiencing this?
    MC 2020.6.0, MacBook Pro (2019), 64 GB Ram, 2.4 GHz 8 Core i9, AMD Radeon Pro 5500M 8 GB [view my complete system specs]
  • Fri, Jun 19 2020 9:39 PM In reply to
    • Joel
    • Los Angeles
    • Posts 12
    • Points 160
    Re: Applying Quick Transition Causes Crash/Unresponsiveness
    After further testing this seems to be a problem with the mouse bindings. I have a 6 button mouse that I map commands to in Avid preferences. The click wheel (recognized as Button 5 in Media Composer) is assigned Quick Transition. In MC 2020.5.0 when I use the click wheel to execute a Quick Transition it looks as though everything is fine, I apply the transition, but when I close the dialog box I am no longer able to play, and am limited in what I can do within the interface. If I use the Quick Transition button above the timeline, however, everything is fine. Seems to be a bug that needs to be fixed. While they're at it can they also add one more mouse button to the preferences panel? That would really help me out!
  • Thu, Jun 25 2020 5:34 PM In reply to
    • Joel
    • Los Angeles
    • Posts 12
    • Points 160
    This problem persists in 2020.6
  • Thu, Jun 25 2020 8:25 PM In reply to
    • Posts 11,208
    • Points 231,130
    Joel:
    Joel
    Your email is not in our system..... can you email me your system ID and MyAvid email so I can get this logged and fixed.
