Latest post Tue, Sep 8 2020 11:47 AM by Audiovisuales Remoto. 5 replies.
Page 1 of 1 (6 items)
  • Wed, May 27 2020 4:38 AM
    Media Composer 2020.4
    Has anyone had the message Reloading plugin: TSParser.acf then composer crashes on startup?
    iMac 2017 3.5ghz core i5. 24 gig ram. Blackmagic mini monitor. [view my complete system specs]
  • Thu, May 28 2020 7:34 PM In reply to
    • mlgoodwin8
    • Joined on Thu, May 28 2020
    • Posts 0
    • Points 0
    Re: Media Composer 2020.4
    I'm having the same issue - holding option while launching will sometimes help get it going. But it often crashes a few times before finally working.
    iMac 2019 (Catalina 10.15.4)8-Core Intel Core i9 (3.6 GHz)64 GB RAMRadeon Pro Vega 48 8 GB(iMac 2013 as a second display) [view my complete system specs]
  • Fri, May 29 2020 7:29 PM In reply to
    • mlgoodwin8
    • Posts 0
    • Points 0
    I'm having the same issue. I've found that option+launching Avid works after a couple tries.
  • Sun, May 31 2020 8:38 PM In reply to
    Yes. Same with me. This is a problem with the external monitor. My computer is iMac from 2019. When I unplug the monitor, Avid starts normally. Then I connect the monitor and I can work. I tested various adapters. Still the same. This has happened since version 2020.04. Never before. Hmmm ... 21st century and such fun.
    I repeat the question. Has anyone observed this?
    iMac 3,6Ghz, Intel Core i9, 32GB Ram [view my complete system specs]
  • Sun, May 31 2020 11:04 PM In reply to
    Interesting, and very boring….
    I never tried to take the other monitor out, but Avid would alternate between crashing on ‘TS Parser’ and then MSP_AVCHD.avx. After a lot of time with Avid support we found and removed MSP AVCHD.avx and things are working again. The problem was there for 2020.4 and 2020.5. Perhaps you could try that?
  • Tue, Sep 8 2020 11:47 AM In reply to
    hi
    taking out the monitor...the mediacomposer runs...but is annoying do it everytime. So where is this MSP AVCHD.aux file exactly? in order to remove it? thanks
