Latest post Mon, May 25 2020 7:18 PM by ripvanmarlowe. 3 replies.
  • Sun, May 24 2020 10:29 PM
    • dmfreeman
    • Michigan
    • Posts 1,860
    • Points 24,390
    Create An Audio Effect
    I would like to create an audio effect where there is an abrupt end, and it almost sounds like a noisy needle being dragged across a phonograph record and the volume and pitch and volume increase.  Any ideas as to the duration it should be, please let me know.
    Denny
    Media Composer 2019.6, BCC Continuum 12.5, , Boris Red 5.6., Asus P9X79 Pro Motherboard with Intel 3930K Processor. 32 gigs DDR3 ram, Windows 10 Pro 1803... [view my complete system specs]
  • Mon, May 25 2020 2:42 AM In reply to
    Re: Create An Audio Effect
    Why not just download this sound effect from an online audio library? There's tonnes of free ones out there and also, this is a very common sound effect, you should have no problem finding many versions of this online. Within Avid there is the Vari-Fi effect which simulates the sound of a record or tape deck distorting as it slows down or speeds up. You could combine this with the downloaded needle scratch effect to give the impression of a turntable being switched off and the needle removed? Pleanty of options.
    Andi
    HP ZBook G6 15 2.6Ghz 6-core i7 9th Gen Nvidia Quadro T2000 4GB 32GB RAM Win 10 Pro MC Ultimate 2018.12.11 MacbookPro 15 2019 6 core 2.6GHz i9... [view my complete system specs]
  • Mon, May 25 2020 7:13 PM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,860
    • Points 24,390
    Hello Andi,
    I followed your suggestion, and it worked like a charm.  Thanks so much for jumping in here and pointing me in the right direction.  Your help is much appreciated.
    Denny
  • Mon, May 25 2020 7:18 PM In reply to
    Awesome! Glad it was of some help!
    Cheers,
    Andi
