When I'm in CC (I have the Symphony option), I find that some of the text is misaligned as shown in the picture below. That's just one example - it happens in other places too.
http://dreamvalley.net
Do you have any scaling going on Windows? I have found that unless I have both monitors at default 100% Avid text is distorted.
Thanks for the reply. It's at 100%. It's only the CC that seems to have the problem, although, I'll re-check that. One thing that comes to mind is that I do use a 1920x1200 monitor. I've used this for years and never had an issue before.
I can confirm that the scaling is the default 100%. It's only happening in CC. I've attached another example of it.
Sorry for the late reply. I have CC option too and my text is fine. I'm convinced it's a windows display issue - I have 2 x monitors at native 1920 x 1080 @ 100% scale, extended desktop, side by side, anything else produces scrunched text. Have another look at your settings, perhaps you have different rez monitors?
An update to this issue.I discovered that it's the 2019.12.1 update that's causing the problem.
I uninstalled 2019.12/2019.12.1 and re-installed 2019.12 only. Everything works fine. All the labels are properly aligned. I then install the 2019.12.1 update and the problem appears. I go back to 2019.12 and it's all working again.
Anyone else seeing this issue with 2019.12.1?
Tried 2019.12.2, which I didn't know existed, and it's the same problem. I also tried 2019.12.2 on Windows 10, a new paritition, and it's got the same problem... And I can also report that 2019.12.0 doesn't produce the issue on Windows 10 either, so it can't be an OS problem.
On Windows 10, v1909, MC 2020.4 does not have the issues.
