Latest post Sun, Sep 6 2020 2:27 AM by mtahir. 8 replies.
Page 1 of 1 (9 items)
  • Wed, May 20 2020 11:13 PM
    • mtahir
    • UK
    • Posts 561
    • Points 6,885
    Text misaligned in CC with Symphony option - v2019.12.1
    When I'm in CC (I have the Symphony option), I find that some of the text is misaligned as shown in the picture below. That's just one example - it happens in other places too.
    MC2022.12 (Win10) | DaVinci Resolve Studio | Dell T7500 with 2 x 6-Core Intel Xeon X5690 3.46GHz CPUs | Triple-Channel 96GB (48GB per CPU) 1333MHz DDR3... [view my complete system specs]
  • Thu, May 21 2020 10:27 AM In reply to
    • Mercer
    • Joined on Thu, Apr 15 2010
    • UK
    • Posts 873
    • Points 11,290
    Re: Text misaligned in CC with Symphony option - v2019.12.1
    Do you have any scaling going on Windows? I have found that unless I have both monitors at default 100% Avid text is distorted.
    MC with Symphony option, 2022.10, HP ZBook 17 G5, i7-8850H 6 core/64GB ram/512 M2 ssd/Nvidia Quadro P5200/16GB/FHD, HP Thunderbolt Dock G2, BMD Ultrastudio... [view my complete system specs]
  • Thu, May 21 2020 7:01 PM In reply to
    • mtahir
    • UK
    • Posts 561
    • Points 6,885
    Thanks for the reply. It's at 100%. It's only the CC that seems to have the problem, although, I'll re-check that. One thing that comes to mind is that I do use a 1920x1200 monitor. I've used this for years and never had an issue before.
  • Sat, May 23 2020 12:21 AM In reply to
    • mtahir
    • UK
    • Posts 561
    • Points 6,885
    I can confirm that the scaling is the default 100%. It's only happening in CC. I've attached another example of it.
  • Mon, May 25 2020 11:07 AM In reply to
    • Mercer
    • UK
    • Posts 873
    • Points 11,290
    Sorry for the late reply. I have CC option too and my text is fine. I'm convinced it's a windows display issue - I have 2 x monitors at native 1920 x 1080 @ 100% scale, extended desktop, side by side, anything else produces scrunched text. Have another look at your settings, perhaps you have different rez monitors?
  • Fri, Aug 21 2020 8:55 PM In reply to
    • mtahir
    • UK
    • Posts 561
    • Points 6,885
    An update to this issue.
    I discovered that it's the 2019.12.1 update that's causing the problem.
    I uninstalled 2019.12/2019.12.1 and re-installed 2019.12 only. Everything works fine. All the labels are properly aligned. I then install the 2019.12.1 update and the problem appears. I go back to 2019.12 and it's all working again.
  • Wed, Aug 26 2020 9:44 PM In reply to
    • mtahir
    • UK
    • Posts 561
    • Points 6,885
    Anyone else seeing this issue with 2019.12.1?
  • Mon, Aug 31 2020 11:50 PM In reply to
    • mtahir
    • UK
    • Posts 561
    • Points 6,885
    Tried 2019.12.2, which I didn't know existed, and it's the same problem. I also tried 2019.12.2 on Windows 10, a new paritition, and it's got the same problem... And I can also report that 2019.12.0 doesn't produce the issue on Windows 10 either, so it can't be an OS problem.
  • Sun, Sep 6 2020 2:27 AM In reply to
    • mtahir
    • UK
    • Posts 561
    • Points 6,885
    On Windows 10, v1909, MC 2020.4 does not have the issues.
