Latest post Wed, May 20 2020 11:00 AM by Lukas Boeck. 2 replies.
  • Tue, May 19 2020 9:05 PM
    When happens to files after a crash?
    I was applying an effect which caused MC to lock up and I had to force a shutdown.   When I rebooted, a video mixdown that I had done before the crash (but probably after the last auto-save) was gone.   I did a new mixdown but I suspect the file to the old mixdown is still on my hard drive?   How can I identify it and delete it?
    Thanks.
    MC 2018.12.3 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system... [view my complete system specs]
  • Tue, May 19 2020 11:22 PM In reply to
    Re: When happens to files after a crash?
    Use the media tool to look for it. It will most likely still show up in there. That's what we used to do when Avid would crash when digitsiing. The clips were gone from the bin but still could be found in the media tool. From there you can drag them back in to a bin. You can sort by drive, project etc and use the column data to help locate it.
    Andi
    HP ZBook G6 15 2.6Ghz 6-core i7 9th Gen Nvidia Quadro T2000 4GB 64GB RAM Win 10 Pro MC Ultimate 2018.12.11 MacbookPro 15 2019 6 core 2.6GHz i9... [view my complete system specs]
  • Wed, May 20 2020 11:00 AM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 592
    • Points 7,020
    and if the file you're looking for has just been created and you can find it in windows explorer easy:
    put it into a new MediaFiles/MXF/[subfolder], let avid scan
    and drag the resulting .mdb into a bin
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-7, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
