Latest post Wed, May 20 2020 5:56 PM by ripvanmarlowe. 1 replies.
Page 1 of 1 (2 items)
  • Mon, May 18 2020 12:14 PM
    Split screen with reference image in CC mode...
    I'm pretty sure you can't do this but I just wanted to double check. In CC mode you can do a split screen with the same image to see a before and after of your grade. Can you do this split screen with a reference image? For example I want to match to the previous image. I can use one of the monitors to display a reference image but I can't compare directly in the same frame.  I want to wipe between my reference and my current image. I can't see any way to do this but thoguht I'd ask.
    Cheers,
    Andi
    HP ZBook G5 15 2.6Ghz 6-core i7 Nvidia Quadro P2000 4GB 32GB RAM Win 10 Pro MC Ultimate 2018.12.8 MacbookPro 15 2019 6 core 2.6GHz i9 32GB RAM... [view my complete system specs]
  • Wed, May 20 2020 5:56 PM In reply to
    Re: Split screen with reference image in CC mode...
    And this issue is exacerbated by the fact the the source/record toggle between current and reference images doesn't work properly, so it makes it very hard to quickly flip between shots.
