Latest post Fri, May 15 2020 10:50 PM by mua. 2 replies.
  • Thu, May 14 2020 2:44 AM
    • mua
    • Joined on Sat, Apr 25 2009
    • Posts 53
    • Points 665
    2020.4.0 MC Cannot see timeline or composer monitor
    I just upgraded to 2020.4 from the older interface and still getting used to the new interface.  I accidentally closed a bin window and my composer and timeline disappeared.  I tried to reset MC to the default edit workspace but it only re-arranges the bin window. I can go to the Tools menu and launch Command Palette, etc. but I cannot get the single or dual monitor display or the timeline.  I even tried to set the Command Palette to active mode, no luck.
    I have tried uninstalling and re-installing MC, created a new user profile, etc.   I even used a backup copy of my project file from Mojave.  It still doesn't work.
    I am most likely missing something very basic with interface.  I was on hold with support for one and half hours and then finally gave up.
    I am grateful for any insights and help.  THANK YOU!
    SYSTEM:  MacPro 2019 / 3.3Ghz, 32GB, AMD Radeon Pro 580X / Catalina 10.15.4
    2019 Mac Pro 12 Core // 2017 MacBookPro // 2010 MacPro 6 core 3.33GHz [view my complete system specs]
  • Thu, May 14 2020 6:54 PM In reply to
    Re: 2020.4.0 MC Cannot see timeline or composer monitor
    Are you able to run zoom on the system. Happy to share screen and see for you.
  • Fri, May 15 2020 10:50 PM In reply to
    • mua
    • Posts 53
    • Points 665
    Thank you, Pat for the kind offer.
    I knew that I might be missing something basic, embarrassingly the issue was that I switched the MacPro from an older to a newer monitor — however, I left the other monitor attached and since it was turned off, I forgot.  For some reason, Avid/MacPro recognized it as a second monitor and moved my composer and timeline windows to the monitor that was turned off.  I am all good now.
