Latest post Tue, Jun 23 2020 6:33 PM by jcmcnamee. 5 replies.
Page 1 of 1 (6 items)
  • Fri, May 1 2020 5:12 PM
    Find Bin improvement
    I normally use the “Find Bin” button to get into the bin of the scene which I’m editing, it’s a quick shortcut that avoids me always to scroll into the project. I think I’m not the only one to use this workaround, and it’s common for editors when you have many bins and folders in your project to open when you work on a scene (sfx, music, sync clips, etc).
    In these new redisigned releases, 2019.6 and 2020.4, I was expecting that the “Find Bin” command would make it to appear into the bin container instead of opening it outside. In such a way, the idea of gathering all  bins into one container fails, and you eventually finish to have a monitor filled with bins at the end of a working day.
    Can this be corrected, so that the "find bin" opens the Bin INTO the bin container and not outside?
    thx
    Alessio
  • Sun, May 3 2020 5:31 AM In reply to
    • TrevorA
    • Posts 1,256
    • Points 14,185
    Re: Find Bin improvement
    +1 too
    iMac 5K on High Sierra MC 2020.5, HP z420 MC 2020.4 [view my complete system specs]
  • Wed, May 6 2020 2:52 PM In reply to
    • pierreh
    • Paris, London
    • Posts 1,269
    • Points 15,355
    There is a "feature request" sub-forum here, I suspect that Avid's engineers read it more than the Mac/PC forums. Might be an idea to post there too.
    - Work: MacPro 2010 3.46Ghz 12 Cores 48Gig RAM, Mojo DX, 10.14.6 - Home: MacBookPro 2.5Ghz quad-i7, 16Gig Mem and SSD OSX 10.11.6 [view my complete system specs]
  • Wed, May 6 2020 9:39 PM In reply to
    thanks, I'll do it right away
    cheers
  • Fri, May 8 2020 10:07 AM In reply to
    • MikeyB
    • Edlesborough, UK
    • Posts 516
    • Points 6,395
    Maybe as a User Setting? There are those of us who still rather like having separate Bins around the place!
    Also, what should happen if you have more than one Bin Container open? I've taken to using Bin Containers like 'live folders' for multiple bins from the same shoot/location/content type etc.
    MacBook Pro 15" 2016 2.7GHz i7 Radeon 455 [view my complete system specs]
  • Tue, Jun 23 2020 6:33 PM In reply to
    • jcmcnamee
    • Brooklyn, NY
    • Posts 287
    • Points 3,050
    This should follow the behavior of the "Double clicking a closed Bin" setting under Bin Settings. It doesn't currently and should change because doing Find Bin on an un-opened bin is basically the same as opening the bin.
    Media Composer 2020.8 / OS 10.15.6 27" iMac 5K 2017 [4.2 GHz Intel Core i7, 64 GB ram, Radeon Pro 580 8 GB] [view my complete system specs]
