Latest post Thu, Jul 23 2020 4:08 AM by Buzzkill. 10 replies.
Page 1 of 1 (11 items)
  • Wed, Apr 29 2020 8:49 AM
    2020.4 When is a JPG not a JPG?
    I posted this in another thread (my mistake): https://community.avid.com/forums/p/199288/893132.aspx#893132
    Mac OS 10.15.3. Here's the thing. I have a load of timelapse JPG stills from a GoPro. They link OK in 2019 and all earlier releases but not in 2020.4. JPGs should link and most of my other test images are fine. I resaved a trial image from Apple Preview at a different compression and that didn't link either. But ... I uninstalled 2020.4 and went back to 2020.2 Beta. In that release, my original JPG didn't link but the copy from Preview did link OK. So - looks like all JPGs are not equal or MC doesn't like some of them but I don't know what the difference is. If anyone at Avid would like my test image, let me know.
    iMac i5 27", 40GB RAM, OS 10.14.6 with Symphony 2020.6, BlackMagic mini monitor. MacBook Pro, 16GB RAM with OS 10.14.6 with MC 2018.12.12 and BMD... [view my complete system specs]
  • Wed, Apr 29 2020 11:53 AM In reply to
    • Posts 11,323
    • Points 232,550
    Re: 2020.4 When is a JPG not a JPG?
    Roger
    send me this info and your Image and I will have it looked at.
  • Thu, Apr 30 2020 10:13 AM In reply to
    • MikeyB
    • Edlesborough, UK
    • Posts 517
    • Points 6,400
    Hi Roger,
    I've had a few jpegs that won't link as well.  There's nothing I can point to as the cause - one was a pic grabbed from a website, one was a pic from my photos library from ages back. Other jpegs work just fine. Very odd!
    MacBook Pro 15" 2016 2.7GHz i7 Radeon 455 [view my complete system specs]
  • Thu, Apr 30 2020 10:16 AM In reply to
    I've sent test files to Marianna. One odd file would be OK but a have a few hundred timelapse images!
  • Thu, Apr 30 2020 10:48 AM In reply to
    Invisible or illegal characters in the filename?
  • Thu, Apr 30 2020 3:04 PM In reply to
    Unliikely. This is a folder full of known files that worked fine in 2019 and earlier releases. And I did rename one to test. If you are right, I've wasted some bandwidth!
  • Mon, Jul 20 2020 11:47 PM In reply to
    • Buzzkill
    • Los Angeles
    • Posts 57
    • Points 795
    Did you ever find a jpg solution, Roger? I've been able to load GoPro timelapse, but having trouble with some older jpg stills. I did try altering names too, but no luck.
    Also having issues loading Sony Venice 4k footage from an AXS-R7, using nablet 4.6.7. Sony Catalyst provided a workaround but hoped for a more direct workflow.
    MC 2020.8|10.15.6|MacPro 16c|96gb|Pro Vega 2|Kona 5|Pegasus32 R8,R4i|Prism ADA8XR|XDR,LG 24MD4KL,Sony PVM2541 [view my complete system specs]
  • Tue, Jul 21 2020 8:06 AM In reply to
    Oh, man! You have opened a can of worms! My original comments that MC 2020.4 on Catalina would not link to JPEGs from my old GoPro Hero 3 got Avid to investigate and start a case (I haven't heard anything recently and other things have distracted me). Until your post just now I hadn't checked with MC2020.6 on Catalina. So I just tried that with bizarre results. A folder of 109 JPEGS (a timelapse from my old GP3) did link, but ... not 109 individual files each with a nominal 30 second duration which is what I'd expect. What actually happened is that the Source Browser seemed to interpret the sequentially numbered files as a file sequence, rather like that option in the Import settings. Even more bizarre is that the lowest numbered file (G0050774) created a moving clip of duration 4:13 and all subsequent files created moving clips one frame shorter than the previous one (4:12, 4:11 ... etc). The last file (G0050882) linked as a still with a duration of 30 secs, which is what I'd expect. G0050774 when linked, played and reported a rate of 24fps even though I was in a 25fps project. Never seen anything like it! Avid? Avid? click the image to see the entire Source Browser.
  • Tue, Jul 21 2020 12:53 PM In reply to
    Oh - guess what? They sneaked in a new Link setting - nice one. So presumably I just select the first file. I must think before I post.
  • Wed, Jul 22 2020 6:35 PM In reply to
    So - a good feature ... but why is this option OFF in the Import settings and ON in the Link settings? It certainly caught me out Sad.
  • Thu, Jul 23 2020 4:08 AM In reply to
    • Buzzkill
    • Los Angeles
    • Posts 57
    • Points 795
    Glad you got that sorted out, Roger. Frustrating why some files load and others don't, with seemingly little/no differences between them.
