Latest post Mon, May 4 2020 11:25 AM by Jacopo Reale. 26 replies.
Page 2 of 2 (27 items) < Previous 1 2
  • Tue, Apr 28 2020 5:10 PM In reply to
    Re: Media Composer 2020.4
    Philo Calhoun:
    No. I have quick time installed now and in past and link or import does not work. You can't manually reimport or link either.
    Philo Calhoun:
    I always liked Avid Media Composer for its stability and ability to open older projects. I'm hoping Avid will release a fix allowing link or importing of H264 files in at least some wrapper. Meanwhile, it looks like the only option is to open older projects with offline footage and to use some other program to transcode the footage to some codec that Avid will import.
    This is not a limitation in MC 2020.x. Something is wrong on your system.
  • Tue, Apr 28 2020 5:26 PM In reply to
    Apparently not per avid tech support.
    Avid Media Composer 2020, OSX 10.15 Mac Pro 2019, 16 core, 48 GB memory. [view my complete system specs]
  • Tue, Apr 28 2020 6:35 PM In reply to
    Philo Calhoun:
    Maybe I don't understand the problem, but based on your description and the documentation of how the UME/QuickTime linking behavior is supposed to work, it seems like something is not working the way it is supposed to.
  • Tue, Apr 28 2020 6:44 PM In reply to
    • tdalauro
    • Joined on Mon, Apr 13 2020
    • Posts 25
    • Points 270
    I haven't found it in the Read Me file - but is there a way to export Same as Source in this new build?
  • Tue, Apr 28 2020 6:45 PM In reply to
    • tdalauro
    • Posts 25
    • Points 270
    Is there not an option to export Same as Source in the new build? What would be the alternative?
  • Wed, Apr 29 2020 1:46 PM In reply to
    • Posts 11,208
    • Points 231,130
    camoscato:
    Philo Calhoun:
    I agree Carl and Philo....   Can you send me this Philo post and any case info you have an I can run it to ground?
  • Wed, Apr 29 2020 2:02 PM In reply to
    • neptunerh
    • Joined on Tue, Jan 29 2013
    • Posts 1
    • Points 15
    I had similar problem... Have you tried simply renaming the MXF folder in your Avid MediaFiles to UME? Then I found that simply opening the Media Tool suddenly reconnected everything.
  • Wed, Apr 29 2020 8:10 PM In reply to
    Unfortunately that did not work with me. It seems any previous AMA link that used quicktime will not relink with UME either through the relink menu or the right mouse click>relink to file command. I have to create a new link with the same file and then overwrite this clip onto the timeline. UME also is much pickier than quicktime on files, and some require re-saving in photoshop or Davinci Resolve.
  • Thu, Apr 30 2020 2:53 PM In reply to
    • Jim Allan
    • Joined on Mon, Jun 7 2010
    • Oakville, Ontario, Canada
    • Posts 106
    • Points 1,200
    My MC 2020.4 is crashing during the log in.
    The only clue I have is that it seems to be hanging up while this is on the screen:
    Initializing plug-in: nablet_MVP_MVP_MSP_XAVC_XDCAM.avx
    Note: I do have OS 10.15.4
    I have also turned off background services as indictaed in the README.
    What have I missed?
    MC v2020.5 with Phrase Find on a 15" MacBook Pro (2017). OS Catalina v10.15.5, 3.1 GHz Intel Core i7. 16GB 2133 MHz LPDDR3. Radeon Pro 560 4096 MB... [view my complete system specs]
  • Thu, Apr 30 2020 2:58 PM In reply to
    Did you install the latest Nablet plugins? Check the Nablet website.
    iMac i5 27", 40GB RAM, OS 10.14.6 with Symphony 2019.12, BlackMagic mini monitor. MacBook Pro, 16GB RAM with OS 10.14.6 with MC 2018.12.12 and BMD... [view my complete system specs]
  • Thu, Apr 30 2020 3:26 PM In reply to
    • Jim Allan
    • Posts 106
    • Points 1,200
    Ahhh.... bingo. Looks like they sent out an email on Jan 25th, that I either missed or ignored. Specifically says there's a fix for Catalina.
    Works now.
    Thank you!
  • Mon, May 4 2020 11:25 AM In reply to
    I hope it can be useful: it is a short tutorial I made to show how to relink via UME. I tested it on Mojave (with h264 media) but it should work on Catalina. The difference should be that on Catalina you have to relink offline media. If you are on Mojave your media are not offline but are linked via old AMA QT engine.
    Here is the link : https://www.instagram.com/p/B_tAkctCdTP/
    Hope it helps!
