Latest post Fri, May 8 2020 11:18 PM by Dom Q. Silverio. 5 replies.
Page 1 of 1 (6 items)
  • Mon, Apr 27 2020 8:06 PM
    • Posts 11,124
    • Points 230,130
    Idea [I] Important |MC 2020.4 | how DNxHD codec MOV files are created!!!!!
    Media Composer 2020.4 contains changes to how DNxHD codec MOV files are created.
    Per the What’s New Document, to make these files compatible with 3rd party applications as well as previous Media Composer versions a new Avid Codecs package needs to be installed on machines not running Media Composer 2020.4.
    These new Avid Codecs are available on the Download Center.
    From the What’s New document:
    It also means that DNxHD MOV files created using UME will require an updated QuickTime PE/LE codec
    package in order to be supported by previous versions of Media Composer and 3rd Party products.
    This is something that everyone needs to be very aware of, so they can handle questions about backward compatibility.
    Thanks JC Bond for pointing this important note out.
  • Tue, Apr 28 2020 6:45 AM In reply to
    • Mercer
    • Joined on Thu, Apr 15 2010
    • UK
    • Posts 495
    • Points 6,305
    Re: Important |MC 2020.4 | how DNxHD codec MOV files are created!!!!!
    I've never been 100% certain - do you need to install LE codecs when MC and PE codecs are already present for full 3rd party software support Marianna?
    MC with Symphony option, 2020.4, HP ZBook 17 G5, i7-8850H 6 core/64GB ram/512 M2 ssd/Nvidia Quadro P3200/FHD, HP Thunderbolt Dock G2, BMD Ultrastudio Mini... [view my complete system specs]
  • Wed, May 6 2020 2:59 PM In reply to
    • pierreh
    • Paris, London
    • Posts 1,263
    • Points 15,240
    Question: if I have a project started on 2019.12 (therefore with "old" DNxHD mxf files), and I move it to 2020.4, will I get into trouble when I export "Same-as-source" since the mxf and the codecs will be a mismatch?
    - Work: MacPro 2010 3.46Ghz 12 Cores 48Gig RAM, Mojo DX, 10.14.6 - Home: MacBookPro 2.5Ghz quad-i7, 16Gig Mem and SSD OSX 10.11.6 [view my complete system specs]
  • Wed, May 6 2020 5:02 PM In reply to
    • Posts 11,124
    • Points 230,130
    pierreh
    Nothing to do with 2020.4 BUT I never change versions until I FINISH a project.  Just saying....
    p.s. hope you are well my friend
  • Fri, May 8 2020 10:05 PM In reply to
    • dharia
    • Joined on Fri, Sep 19 2008
    • Posts 182
    • Points 2,290
    Also I wanted to ask. We export DNXHD 220 10 bit files from MC 2018 to a TV network who processes that file through their QC system and sends for air, FOX Sports. If I had 2020.4 and exported a DNXHD 220 10 bit quicktime does that mean they wouldn't able to even read it (since they might be on some legacy system that reads DNXHD 220 and sends it for air?)
  • Fri, May 8 2020 11:18 PM In reply to
    Mercer:
    PE codec package is all you need.
    MC 2019.12, W10, Gigabyte X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 32GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012... [view my complete system specs]
