Latest post Mon, Apr 13 2020 7:11 PM by Richard. 8 replies.
Page 1 of 1 (9 items)
  • Sat, Apr 4 2020 11:49 PM
    Source Color Correction prior to Grouping
    Here I am again with a multicam shoot, a 2 camera interview. I want to match the color correction on them prior to grouping and cutting as a multicam. I put them into a sequence and did my color and saved the effect... how t apply this to the source clips prior to grouping is my question.
    Media Composer 2019.11 Home-built Windows 10 Pro Asus Z87-A Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz, 3101 Mhz, 4 Core(s), 4 Logical Processor... [view my complete system specs]
    "Don't go by my script, they're always wrong." - producer to me while editing
  • Sun, Apr 5 2020 2:59 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 591
    • Points 6,995
    Re: Source Color Correction prior to Grouping
    Funny question coming from a symphony moderator Stick out tongue
    In symphony, you'd apply the correction in "master clip" mode.
    in color corredction mode, there's a drop down list top left of cc interface.
    In standard Media Composer you'd give each master clip a different color and multiselect and multi-apply to identical colors.
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-7, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
  • Sun, Apr 5 2020 10:55 PM In reply to
    • dew
    • Joined on Tue, Feb 27 2007
    • Posts 593
    • Points 7,525
    Yea I needed to do this instead of grouping and them trying to match the 2 cams. A freaking headache and what sucks more I don't have symphony just regular MC.
    So would be the steps to take for MC in this situation?
  • Mon, Apr 6 2020 12:10 AM In reply to
    • Lukas Boeck
    • Austria
    • Posts 591
    • Points 6,995
    Give each camera a seperate source color in bin.
    set checkmark - hamburger menu timeline -> clip color -> Source
    Edit video using your group.
    Apply each CC preset to clips of same color. either manually, shouldn't be that bad, or,
    find some wizardry to auto selct same color. might exist.
  • Thu, Apr 9 2020 9:02 PM In reply to
    I figured out a solution! After you create a group, right click on the group and select "edit group". It then opens it up into a timeline where I apply the color correction effects I saved. Boom done. Now I can cut with the material color corrected prior to doing the multi-cam edit.
  • Fri, Apr 10 2020 2:05 AM In reply to
    Brilliant! Can't wait to try it. Is this on a Symphony or MC?
  • Sun, Apr 12 2020 8:25 AM In reply to
    • dew
    • Posts 593
    • Points 7,525
    Scott Carnegie:
    So lets say I did the mulitcam edit first and then went to edit group and applied the CC effect. Is there a way to update the multicam edit to reflect the new CC effects that where applied?
  • Sun, Apr 12 2020 11:29 PM In reply to
    • dew
    • Posts 593
    • Points 7,525
    Scott Carnegie:
    This is not working for me. Have you tried it out? When I apply the Cc effect, hit update the effect is not updating in the group clip.
  • Mon, Apr 13 2020 7:11 PM In reply to
    • Richard
    • Joined on Fri, Aug 17 2012
    • Los Angeles
    • Posts 51
    • Points 615
    That's correct:  I tried it, too, and the correction does not transfer to the group clip.  I've always had to open an individual clip in the TL, do the CC, then mix down to a separate video file and that separates the video/audio.  I'd like to be able to correct the clip up front, maintaining the connected audio.  Must not be able to.
    MC2020.6 on home-grown IntelCore i7 3.07GHz, 24GB ram, Quadro K4000 (Nvidia driver 340.84), Win 10 Pro 64, Acer, dual 22" monitors, 2-1TB internal... [view my complete system specs]
