Latest post Thu, Apr 9 2020 4:40 PM by MartinY. 1 replies.
Page 1 of 1 (2 items)
  • Fri, Mar 27 2020 5:42 PM
    • MartinY
    • Joined on Fri, May 24 2019
    • Posts 3
    • Points 25
    Using both PackageName and Material Name in AMT3
    I would like to create MXF files that set the Avid BIN Name and Tape columns independently.
    For example Name to A003C009_101129_R1V8 and Tape to A003R1V8
    Dropping an AMT2 created MXF Op-Atom file into the MediaInfo app shows the package name as A003R1V8 / A003C009_101129_R1V8
    In AMT2 this was possible as follows…
    Name = folder name sent to CreateAmtFile
    Tape = tapeName in the destination media properties XML
    In AMT3 I get either the PackageName or the Material name depending on the DescriptorType as follows…
    DescriptorType = TapeDescriptor
    Name = PhysicalSourceInfo.PackageName
    Tape = PhysicalSourceInfo.PackageName
    DescriptorType = ImportDescriptor
    Name = MaterialName
    Tape = Blank
    There is the jobDefinition.mediaParameters().tapeName() call, but this also applies the string to both Name and Tape.
    I see MaterialName in the PresetsAndOverrides.xsd, but can't see how this is used or even if it's relevant ?
    It would be great if in TapeDescriptor mode both the PackageName and the MaterialName were used.
    Many thanks,
    Martin
  • Thu, Apr 9 2020 4:40 PM In reply to
    • MartinY
    • Posts 3
    • Points 25
    Re: Using both PackageName and Material Name in AMT3
    Anyone any thoughts about this?? A solution would make my Easter and I'll also help someone else by donating to charity if there is a solution.
    Martin
