Latest post Wed, Apr 8 2020 7:56 PM by DStone. 21 replies.
Page 2 of 2 (22 items) < Previous 1 2
  • Tue, Apr 7 2020 7:56 PM In reply to
    • nehrer, fabio
    • Joined on Fri, Nov 26 2010
    • Rio de Janeiro, Brasil
    • Posts 22
    • Points 280
    Re: Export mov container with xdcam hd 422 codec
    - I exported from AMC as mxf xdcam hd.
    - I went to the Shutter Encoder rewrap as a mov.
    - When I try to open the file made by Shutter in QT he informs that he cannot reproduce this format and asks to go to the apple website to resolve it. The site opens but informs me that the data on the page was not found.
    - I try to open it in VLC and it says: "Codec not supported:
    VLC could not decode the format "m2v1" (No description for this codec) "
    - When I go to AMC it doesn't allow me to link the mov file, just import the file, and when I import the video it doesn't come correctly. It is green screen.
    - When I link to AMC the original MXF (which I exported to generate the mov) comes normally.
    MC 2019.12 - AS ROCK Z390 PHANTOM GAMING X - NVIDIA QUADRO P2000 (431.02) - INTEL I7 8700K - WINDOWS 10 PRO - QUICKTIME 7.7.9 - TEAMGROUP DDR 4 2 X 16... [view my complete system specs]
    fabio nehrer
  • Tue, Apr 7 2020 8:11 PM In reply to
    That QT and MC linking don't work would make sense since you don"t have an XDCAM Quicktime codec installed.
    Does VLC let you play other XDCAM movs?
  • Tue, Apr 7 2020 9:59 PM In reply to
    • nehrer, fabio
    • Posts 22
    • Points 280
    I thought the AMA QT plugin that comes pre-installed would access mov files. Including xdcam 422 mov. But apparently it only allows xdcam in mxf, both for import and export. So in theory the xdcam hd mov file that I created will work on a machine that has the specific codec to read and write xdcam mov. Codec that is sold only by Calibrated ...
    fabio nehrer
  • Tue, Apr 7 2020 10:20 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,742
    • Points 47,935
      Moderator: MCA Mac
    A little bit of research later and it turns out that the only way you can only to get XDCAM in a MOV file is on a MAC using FCP or on the PC using Calibrated.
    And now for the $64,000 question (which at least half the people reading this have no idea where this comes from): Why do you need to have XDCAM 422 in a MOV container?
    Dave S.
  • Tue, Apr 7 2020 10:59 PM In reply to
    • nehrer, fabio
    • Posts 22
    • Points 280
    Now, I'm on remote work. I work for the government on TV Brasil, and the final product there must be in mov $ony xdcam hd, this was due to a large number of employees who have no idea what they are doing. Or rather, they knew exactly what they were doing ...
    P.S. At moment i dont have any material in xdcam mov to test.
    fabio nehrer
  • Wed, Apr 8 2020 4:49 PM In reply to
    • nehrer, fabio
    • Posts 22
    • Points 280
    Apparently even Calibrated does not do this anymore ... The plugins indicated at https://www.avid.com/plugins/ama-plugins are no longer sold.
    fabio nehrer
  • Wed, Apr 8 2020 7:56 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,742
    • Points 47,935
      Moderator: MCA Mac
    Then your sole option is to use FCP on a Mac, or trust that the rewrapped video works as-is, If nothing else, send a rewrapped video to someone who has a Mac and FCP and see if it works.
    Dave S.
