Latest post Thu, Mar 26 2020 1:19 PM by LDV20. 4 replies.
  • Wed, Mar 25 2020 2:48 PM
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 256
    • Points 3,075
    Does Frame Flex work on a subclip
    Made a subclip and need to blow up for a close up.   However not seeing framflex working -anything I am doing wrong?   Just read that I had to also apply it to he original clip but would rather not.
    thanks you
    Symphony 2019.12- Win 10 pro (1809), Asus PrimeZ270 with i7 7700 cpu, Quadro P2000,(431.02) 64gig memory, 500gig SSD system drive, WD 5TB,and 2TB media... [view my complete system specs]
  • Thu, Mar 26 2020 9:45 AM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 661
    • Points 8,260
    Re: Does Frame Flex work on a subclip
    Frameflex needs to be done to the original master clip, but of course that would mean it would apply to all instances of that clip on the timeline (assuming you've refreshed your sequence).
    What you can do is to apply the clip to the timeline without any blow-up, then go into effect mode, where you can see the Frameflex as an effect. If you blow the shot up here (rather in the Source Settings) it will only effect that clip and not the whole master clip.
    HP Z800, HP G3 Studio, SonnetFusion RAID, Mojo DX, Symphony 2018.9, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color, Avid Transport [view my complete system specs]
  • Thu, Mar 26 2020 11:51 AM In reply to
    • LDV20
    • Posts 256
    • Points 3,075
    Good -  thank you was going to use re-size but will use this method.
  • Thu, Mar 26 2020 12:00 PM In reply to
    • Bruno M
    • London, UK
    • Posts 661
    • Points 8,260
    If you use resize, you will be blowing up the image based on your project settings. If your rushes were UHD but your timeline is 1080, you'll not be able to utilise the resolution of your original rushes, but just blowing up 1080.
    With Frameflex, you will be to take advantage of all the available resolution.
  • Thu, Mar 26 2020 1:19 PM In reply to
    • LDV20
    • Posts 256
    • Points 3,075
    Yes - I meant i will use the method you suggested.  Actually about to do it now.  I did have an occassion a while back after getting a project from resolve and then getting it back into MC - somehow I lost a CU of shot I where I used Framelflex.  I did do a reaize in mc for the CU maybe 30 -40% and it still looked good - I got lucky.  Footage was Pro Res 4k 10bit
    Anyway you are right and will try your method now.
    Thank you
    Larry
