Latest post Sat, Mar 21 2020 8:37 PM by Lukas Boeck. 3 replies.
  • Thu, Mar 19 2020 2:53 AM
    • eyeqjim
    • Chicago & Burbs (Geneva)
    • Posts 177
    • Points 2,340
    Export issue, file dwnld to hard drive but won't to external devices
    Avid folks.  I finally found a setting to export my completed file.  It exported h264 1280x720... looks great.
    Now I'd like to give this file to the client.  I used a 32gig USB stick... after first trying to copy the file ( 6 gig )  to a USB stick ( 32gig ) it wouldn't copy,  stating the file was too big.  Then I tried to re-download from avid to export directly to the stick,  many hours later,  it reads file too large,  adjust the general settings...I tried this a couple different ways,  nothing worked...
    Any ideas? I have the file on my hard drive, & desk top, but need to give it to the client.  It is saved as a MOV.  H264 file.
    Avid Media Composer online Dell 7810 Dual Dell 17in monitors / DV keyboard [view my complete system specs]
    Cheers!
  • Thu, Mar 19 2020 4:54 AM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 260
    • Points 2,765
    Re: Export issue, file dwnld to hard drive but won't to external devices
    Check the format of your USB stick FAT32 has a 2gb file limit.
    reformat the USB stick to a more modern file format suitable for your client
  • Thu, Mar 19 2020 6:19 AM In reply to
    • eyeqjim
    • Posts 177
    • Points 2,340
    Thank you. I did and I did have it formatted to fat32, I did not see a limit. Nontheless, I tried a fast memory card I had ( sd ) and it copied over in seconds! I never knew that a usb stick, the kind I bought would not copy a large file, I figured they were slow but had no idea they would just not copy it! Big thanks!!
    Cheers!
  • Sat, Mar 21 2020 8:37 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 578
    • Points 6,835
    And exporting h264 from avid is about the slowest and lowest quality way to make an mp4.
    try exporting DNxHD 115/120 and encoding in say handbrake.
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-7, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
