Latest post Sun, Jul 19 2020 11:27 AM by Aaron. 13 replies.
Page 1 of 1 (14 items)
  • Wed, Mar 18 2020 10:33 PM
    • Kyler
    • Joined on Wed, Feb 26 2014
    • Boudreau
    • Posts 84
    • Points 950
    Export to File = No Quicktime or Same as Source
    I'm on the beta of Avid MC (v2020) and in a 4K project. When I go to File > Output > Export to file, there are no QT options any more. I can only do things like MXF, OMF, etc.
    Anyone have a clue on this? I'm a 4K / 24 frame project using AMA linked footage that I've transcoded to DNxHR.
    Is there any way to get my sequence out of Avid without Quicktime available? I've got a deadline looming and need to sort this out before I'm in trouble.
    Thanks for any help!
    Macbook Pro / G-Raid Shuttle [view my complete system specs]
    kyler boudreau | kylerboudreau.com
  • Wed, Mar 18 2020 11:34 PM In reply to
    • dingo1
    • Grinnell
    • Posts 339
    • Points 4,045
    Re: Export to File = No Quicktime or Same as Source
    Is there a specific deliverable you need for the client?  I've been using MXF OP1a exports.  From there I make whatever the client needs from media encoder (older version that still supports QT).  Hope that helps
    MC 2020.6 on 2019 MacBook pro 64 gigs ram Symphony v2018.12 on 2011 iMac i7 48gig ram tons of firewire single drives Symphony v 2020.4. on 2019 IMAC... [view my complete system specs]
  • Thu, Mar 19 2020 12:01 AM In reply to
    • Kyler
    • Boudreau
    • Posts 84
    • Points 950
    Just need a high resolution 4K quicktime. I don't have Media Encoder, only Apple Compressor. =|
  • Thu, Mar 19 2020 12:02 AM In reply to
    Kyler:
    Yes, read the documenation about the Beta.
    MC 2020.6, W10, Gigabyte X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 64GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012... [view my complete system specs]
  • Thu, Mar 19 2020 12:06 AM In reply to
    • Kyler
    • Boudreau
    • Posts 84
    • Points 950
    Bummer man. Time to format my Mac and go back to an older OS.
  • Thu, Mar 19 2020 12:11 AM In reply to
    Try finding a free FFMPEG GUI. It is able to read MXF and covert to MOV.
  • Thu, Mar 19 2020 8:09 AM In reply to
    Shutter Encoder.
  • Thu, Mar 19 2020 1:17 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,443
    • Points 17,810
    Job ter Burg:
    Shutter Encoder.
    +1  The interface is a little quirky, but I liked it so much I donated.  Forgot it was free!
  • Thu, Mar 19 2020 2:34 PM In reply to
    I donated too, the minute I started using it, as it is so helpful.
  • Fri, Mar 20 2020 1:35 PM In reply to
    ive been exporting op1a legacy and then making quicktimes in the free Davinci. works fine.
  • Fri, Mar 20 2020 4:26 PM In reply to
    • Kyler
    • Boudreau
    • Posts 84
    • Points 950
    I just moved back to Mojave. Don't like introducing extra software into the process. I'm never going bleeding edge on Mac again! Lol.
  • Thu, Jul 16 2020 3:47 PM In reply to
    • Aaron
    • Joined on Thu, Apr 11 2013
    • IL
    • Posts 2
    • Points 20
    I am almost sure that in new versions of 2020 Media Composer add option to output in Quicktime
    MC 2020.6, WIN10 For workstation 20H2, SuperMicro-X10DAX, Intel-Xeon 2xE5-2667 v3, AMD RX580, 256GB 2133-Ecc RAM, Kingston 240G SSD [view my complete system specs]
  • Thu, Jul 16 2020 5:55 PM In reply to
    Aaron:
    Yes, as long as you're not on Catalina. And if you're on a non-Catalina Mac, you need to run the separate installer for Legacy Components.
  • Sun, Jul 19 2020 11:27 AM In reply to
    • Aaron
    • IL
    • Posts 2
    • Points 20
    Kyler:
    Hey, Kyler
    I solved the problem like this, I downloaded Quicktime here
    After installation, i got the quicktime export option
    If this method helps someone I will be very happy
