Latest post Sun, Mar 15 2020 11:17 AM by Pulck. 2 replies.
  • Wed, Mar 11 2020 11:36 AM
    • Pulck
    • Joined on Fri, May 26 2006
    • London, UK
    • Posts 101
    • Points 1,270
    Working from home and Interplay
    I'm an editor working on an archive-based documentary series (5 Media Composer cutting rooms running 2018.10.0) using the Interplay system. This is my first time using Interplay, so I'm not very au fait with its capabilites/limitations.
    Given the current escalating situation with the coronavirus, I think we should be planning for working from home.
    What are our options?
    Would the simplest - albeit low-tech - solution be to just copy all Avid media files and projects to external hard drives and then just plug in at home? (I'm guessing there's in excess of 10TB of media.)
    Can we just run plain vanilla Media Composer at home and access the media? I seem to remember there are restrictions with Interplay licenses. But if we have moved all the media onto external drives, does that restriction apply?
    Any suggestions most welcome.
  • Sun, Mar 15 2020 10:51 AM In reply to
    • TrevorA
    • Posts 1,211
    • Points 13,660
    Re: Working from home and Interplay
    You can copy media to external drive and access with standalone MC. No license restriction.
    Media has to be in proper folder structure with numbers to get indexed by local machine (i.e. interplay has other characters in the folder name to prevent this).
    http://djfio.com/mdv/ may help
  • Sun, Mar 15 2020 11:17 AM In reply to
    • Pulck
    • London, UK
    • Posts 101
    • Points 1,270
    Thank you! That's very helpful.
