Latest post Mon, Mar 2 2020 9:05 PM by cls105. 5 replies.
Page 1 of 1 (6 items)
  • Sun, Mar 1 2020 12:07 AM
    Mute Clips should be a single TOGGLE Key
    Mute Clips is a binary tolggle function so why is it two separate keys?
    Switching tracks on and off are also binary toggles and they are just a single key which toggles on and then off (as you'd expect).
    Can "Mute Clips" also be made to do this so I don't waste two keeys of my already overflowing keyboard settings?!
    Jonno
    iMac (27", Late 2013, 3.5 GHz Intel Core i7, 32 GB, OS X 10.12.6) Connected to 27" Thunderbolt Display, BlackMagic UltraStudio Express (10.7... [view my complete system specs]
    www.fusspotfilms.com
  • Sun, Mar 1 2020 8:41 AM In reply to
    • Cutyes
    • Joined on Sat, Jan 14 2012
    • Berlin
    • Posts 180
    • Points 2,330
    Re: Mute Clips should be a single TOGGLE Key
    From another thread:
    Cutyes:
    Hm, I see that there might be specific situations in which toggling could be the better option for a given task. But in general I would rather say that the separate commands give you better control. To mute/unmute the whole timeline or a bunch of consecutive clips, toggling would be fine. But, for example, if you had a mixed series of clips, some already muted and some not, and you wanted to mute or unmute all of them, toggling would just invert the clips. The command wouldn't know whether to leave the unmuted clips unmuted or the muted clips muted.
  • Sun, Mar 1 2020 10:12 AM In reply to
    Cutyes:
    ...for example, if you had a mixed series of clips, some already muted and some not, and you wanted to mute or unmute all of them, toggling would just invert the clips.
    Funnily enough, I can also see where that could be a useful function, particularly if you had two sets of several audio clips prepared that I wanted to play to the director, one set first and then select both sets, toggle Mute, then play the other set. That would be quicker than clicking several tracks' tiny mute buttons and then click the other set of tracks to unmute them OR select each set, Mute the unmute set, select the other and Unmute that. These current mrthods take time that directors often don't have the patients for.
    I guess it could be a user preference where you could decide in advance if you prefer to toggle 'opposite' status OR toggle 'all status' on or all off no matter their status (if any clips were not the same mute status as the others in the selection, that is).
    Do you have a link to the other thread that I should probably post this on?
    Jonno
  • Sun, Mar 1 2020 10:36 AM In reply to
    • Cutyes
    • Berlin
    • Posts 180
    • Points 2,330
    The other thread was this one:
    https://community.avid.com/forums/p/196726/880253.aspx
    But it was not mute/unmute specific nor elaborated.
  • Mon, Mar 2 2020 8:15 PM In reply to
    Thanks for the link. I guess that makes two of us who would prefer it. But I do see your point (hence the setting suggestion).
    further to the Mute Clip function, does anyone know if the AAF output error, where avid doesn't copy (or consolidate) Muted media, has been fixed yet? I have only just started using 2019-12 so haven't had an opportunity to test this yet.
    At the very least, it should be an option in the export settings to include 'muted clip media'.
    Often these mute clips are alt takes of dialogue for the sound team. Currently just these clips display in protools with no media. So we have to manually search the film for them and either copy muted clips to a new sequence, unmute them, then export aaf of that sequence in addition to the main aaf OR find each muted clip, unmute, adjust volume to -99dB (I mean infinity but can't find the character on my phone) before exporting the AAF. Both methods are quite cumbersome.
    jonno
  • Mon, Mar 2 2020 9:05 PM In reply to
    • cls105
    • los angeles
    • Posts 522
    • Points 6,730
    Yup.  I've made this request in the past.  https://community.avid.com/forums/t/198708.aspx
    I agree.  Mute and unmute should be the same keystroke.
    w10, mc 2020.4, diy x299 7940x [view my complete system specs]
