Latest post Wed, Jul 8 2020 10:06 AM by Corne Scheepers. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Feb 21 2020 1:38 PM
    Reordering clips in a Group Clip for multicam
    Is there a way of reordering the clips in group clip when doing multicam editing? I do most of my interview edits through multicam with the visuals coming two or three cameras and the audio coming from a seperate audio recorder.
    Process as follows:
    1) Import all media. Select all clips, Autosync with Group Clip selected (making sure the Zoom audio track is at the top of the pile) sync using waveform analysis.
    2) Edit multicam mode into sequence using quad display
    Once I've made a group clip, is there any way or changing the order of clips, or even replacing individual clips in that group?
    Using MC 2019.12 Win
    Avid Media Composer 2020.4 HP ZBook 17 Gen3, i7-6700HQ CPU @ 2.60Ghz Win 10, 64GB RAM [view my complete system specs]
  • Fri, Feb 21 2020 2:59 PM In reply to
    Re: Reordering clips in a Group Clip for multicam
    Right click the group clip icon in the bin and choose Edit Group. This will un-collapse (de-collapse?) your grouped sequence and show you your sync map.  Here you can make your changes or add or remove cameras etc.
    Then right click the record monitor and choose "update group". Avid will ask if you want to update the current group or create a new one. Creating a new one gives you a new group clip in your bin. Updating the group just updates the already existing group clip in your bin.
    Annoyingly I haven't figuered out how to easily update the sequence with the new group clip information other than by re-cutting the updated group clip back over your existing timeline. In other words, when you choose to edit the group, Avid un-collapses the timeline, but when you choose to update the group, Avid doesn't then collapse the timeline back down again. It literally only updates the group clip.  So I have to then cut the updated group clip back on to the existing timeline.  I'm not sure if I am just missing something or if this is truly the case, but if it is then there is definitely room for improvement.
    Anyway, that's how you can update a group clip.
    Andi
    HP ZBook G6 15 2.6Ghz 6-core i7 9th Gen Nvidia Quadro T2000 4GB 32GB RAM Win 10 Pro MC Ultimate 2018.12.11 MacbookPro 15 2019 6 core 2.6GHz i9... [view my complete system specs]
  • Fri, Feb 21 2020 3:21 PM In reply to
    ripvanmarlowe:
    Andi
    Thanks for this Andi! Will check it out tomorrow. In all honesty I didn't think this was even possible...good news!
  • Fri, Feb 21 2020 3:38 PM In reply to
    Ok, so I figured out how to update the sequence.  You need to make your changes to your group clip, then highlight the sequence that contains that group clip, rightclick and choose "Refresh Sequence > Group Edits". This then updates the sequence with your changes.
    HOWEVER...  I've actually just noticed a very major limitation of grouping in this manner - you cannot shorten the length of a group.  You can only add cameras.  I just tried taking an already built sync map that I had made and removing a section from the middle. Then updated the group clip and refreshed the sequence by going to Clip > Refresh Sequence > Group Edits.
    I either get no change - the sequence does not update to show where the gap should be, or I get the error Exception: PMM_INSUFFICIENT_MEDIA.
    The manual actually states that this is a current limitation - see attached screenshot.
    So it looks like refreshing the sequence to update it is a no go if you make the new group shorter.  You'll still have to cut the new group clip in over the top of your current sequence.  If you add to the sequence then it works.
    This is a pretty major limitation - Avid - when will this be addressed or has it already been in a newer version? I'm working on 2018.12.7.
    Andi
  • Tue, Jul 7 2020 9:33 PM In reply to
    • lando2000
    • Posts 6
    • Points 80
    Not sure if you ever got your answer, but:
    If you're just talking about the order the cameras appear in your split (quad or nine), you can rearrange/reorder by holding down COMMAND (OPTOION on PC I believe) and clicking on whichever box you'd like to change. This opens a list of all available cams in the group, and you can select which cam you'd like (MC then swaps positions for those two cams--so for example, if CAM G is in box 3, and you want it in box one, clicking on box one and selecting CAM G from the list will put it in box 1, and whatever cam was in box 1 will now be in Box 3).
    This is really useful if the sets of cameras are following specific subjects, and whoever is grouping doesn't know how to set the order PRIOR to grouping, OR if the cameras swap which subjects they are following midway through a group!
    Hope this helps!
  • Wed, Jul 8 2020 10:06 AM In reply to
    Thank you for your reply! I'm going to check this out. It is exactly what I wanted to do!
