Latest post Sun, Feb 9 2020 1:35 PM by WAIF2318. 4 replies.
  • Fri, Feb 7 2020 2:24 AM
    • WAIF2318
    • Joined on Tue, Nov 15 2011
    • Posts 334
    • Points 4,155
    a particle effect for pictures or videos?
    Hi,does AMC have third-party special effects plug-in software that can particleize pictures or videos?
  • Fri, Feb 7 2020 2:13 PM In reply to
    • dew
    • Joined on Tue, Feb 27 2007
    • Posts 588
    • Points 7,450
    Re: a particle effect for pictures or videos?
    Borisfx. Not a lot of tutorials unfortuntely. Not a lot of effects tutorials for avid at all come to think about it.
    https://www.youtube.com/watch?v=ejqwPydTsP0
  • Sun, Feb 9 2020 2:43 AM In reply to
    • WAIF2318
    • Posts 334
    • Points 4,155
    thanks to dear dew.
  • Sun, Feb 9 2020 12:51 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,745
    • Points 61,895
    You could also use BMD Fusion Studio ($300) with its Fusion Connect plugin into Avid for some elaborate particle effects. Here's a link to a YouTube tutorial by VFXStudy: here. This shows the use of Fusion. It does not show the use of Fusion Connect into Avid although you could check out this one here to get a sense of the general workflow.
    It's not quite the same as using BCC (which I highly recommend, although it's expensive) - but the things you can do in Fusion are quite impressive.
    Add - I should mention that the Fusion Connect tutorial uses a very old version of both Fusion and Avid. If you are running Media Composer 2018.7 or later you will require the use of the paid version of Fusion Studio 16.1.1 and the latest Fusion Connect plugin (the plugin is available for download at the BMD support page, Fusion Studio 16.1.1 must be purchased through a 3rd party such as B&H Photo Video - online they are selling the Fusion 9 license (it's a dongle) - this will allow you to run Fusion Studio 16 and also Resolve Studio 16 - so it's a two for one if you buy the Fusion Studio dongle).
    Cheers
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sun, Feb 9 2020 1:35 PM In reply to
    • WAIF2318
    • Posts 334
    • Points 4,155
    Thanks to BarkinMadd for your explanation, very good information.
