Latest post Sat, Feb 22 2020 11:57 PM by Glenno. 3 replies.
  • Thu, Feb 6 2020 10:22 PM
    • edittri
    • Joined on Wed, Apr 25 2018
    • Posts 3
    • Points 35
    Insert Edit Export Greyed Out
    Mac OS High Sierra 10.13.16
    Avid 2020.2 public beta
    Most of the time Insert Edit Export is greyed out under the output menu.  Randomly it will be available as an option and will output, but then the next time I check with nothing else changed except in and out points on the sequence and it is greyed out again.  Can not figure out the sequence of events that enables the function.
  • Thu, Feb 6 2020 10:44 PM In reply to
    Re: Insert Edit Export Greyed Out
    nevermind
    MC 2019.9, Windows 10, ASROCK X99M, Intel 5930K, Gigabyte 2080Ti Auorus, 32GB RAM, Samsung 960 Pro M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012... [view my complete system specs]
  • Fri, Feb 21 2020 9:32 PM In reply to
    • edittri
    • Posts 3
    • Points 35
    Not sure what nevermind means on this post.  I'm now on the Beta 3 build and Insert edit export is still greyed out as an option most of the time.
  • Sat, Feb 22 2020 11:57 PM In reply to
    • Glenno
    • Joined on Wed, Nov 19 2008
    • Posts 87
    • Points 1,160
    Insert edit is greyed out when the Timeline window is selected, if you select the Composer window or Bins then the Insert Edit Option is available. It's been like this ever since the Insert Edit function was released, not sure why.
