Latest post Wed, Feb 5 2020 5:56 PM by alexdetig. 4 replies.
  • Tue, Feb 4 2020 1:59 PM
    • alexdetig
    • Joined on Wed, Jan 15 2014
    • Posts 49
    • Points 650
    Aliasing issue with FrameFlex...and the support has no idea...
    Hi.
    I got an issue with FrameFlex. In a HD project I use 4k ProRes and DnX clips.
    When I zoom into the 4k-clips with FrameFlex (Maximun to HD res in this 4K)  the resolution is bad, I get jaggies and stairs (aliasing)
    Any workaround?  AVID support is not able to help me at this time...
    Annoying....
    Angry
  • Tue, Feb 4 2020 2:52 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,456
    • Points 17,975
    Re: Aliasing issue with FrameFlex
    Try typing EDO ACPLCPU into the console, then switching your video tracks off and on.
    This resembles a known bug on the PC side.
    http://community.avid.com/forums/t/197880.aspx?PageIndex=2
  • Tue, Feb 4 2020 5:59 PM In reply to
    • alexdetig
    • Posts 49
    • Points 650
    Updated to 2019.12
    Issue still there...
    Angry
  • Wed, Feb 5 2020 4:54 PM In reply to
    • tpowell
    • Joined on Wed, Dec 10 2014
    • Posts 51
    • Points 615
    Also, try rendering the effect and exporting as a test. I have found playback anomalies (especially with the display resolution set to green/yellow) that go away once the project is exported. This might not fix it, but it will let you know if it is a display issue or something else.
  • Wed, Feb 5 2020 5:56 PM In reply to
    • alexdetig
    • Posts 49
    • Points 650
    Nop. The issue will be in exports too.
    Tried it with several settings....
    Sad sad thing.....
