Latest post Tue, Nov 3 2020 11:50 PM by trackology. 4 replies.
  • Fri, Jan 31 2020 2:33 PM
    Recommended way to work with Alpha Channel Clips in Media Composer 2020
    I'm wondering what the recommended way to work with Alpha Channel clips is with Media Composer 2020 (beta and beyond), now that it appears we no longer have support for QuickTime ProRes 4444 which was the previous method I used to get lower thirds, etc with alpha channels into Media Composer from After Effects.
    Can we somehow export a DNxHR with alpha as a MXF file? It would be wonderful if this option could be consolidated/transcoded into a native media composer MXF file so I don't need to worry about a handful of external files with alpha channels when moving and archiving projects. It would also be nice if the performance of alpha channel media was improved, but perhaps that's asking too much ha ha.
    Thanks!
  • Wed, Jul 15 2020 10:45 AM In reply to
    • Gareth
    • Joined on Tue, Jun 15 2010
    • Midlands, UK
    • Posts 27
    • Points 390
    Re: Recommended way to work with Alpha Channel Clips in Media Composer 2020
    I am after this info too, did you ever work it out? I cant find the answer online or from testing as to how to get clips with alpha from AE to Avid?
    iMac Pro iMacPro1,1 (2017) 10-core 3 GHz Intel Xeon W, 64 GB 2666 MHz DDR4, Radeon Pro Vega 64 16 GB [view my complete system specs]
  • Wed, Jul 15 2020 11:37 AM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,454
    • Points 17,955
    PNG Sequence?  Slower than the old way, but it gets you there.
  • Wed, Jul 15 2020 1:48 PM In reply to
    • addinski
    • Erfurt, Germany
    • Posts 193
    • Points 2,330
    Can´t you export DnxHD/DnxHDr with alpha out of AE and then import that into Avid via fast import? That´s how I do it on 2018.3.
    Andre.
    MAC OS X 10.11.6 AVID MC 2018.3 + Avid Mbox Pro 3 MACBOOKPRO 15" Retina, i7 2.66 GHz Quadcore, 16GB Ram Dell UltraSharp U2711 Sony FS5 & Alpha... [view my complete system specs]
    Honestly I hate editing.
  • Tue, Nov 3 2020 11:50 PM In reply to
    • trackology
    • Joined on Wed, Mar 12 2014
    • Posts 4
    • Points 40
    not if that DNxHD/DNxHR is in a quicktime wrapper!  The only way that has worked for me is PNG sequence with alpha!
