Latest post Thu, Jan 30 2020 11:15 PM by Lukas Boeck. 1 replies.
Page 1 of 1 (2 items)
  • Wed, Jan 29 2020 3:40 PM
    • bushfilm
    • Baton Rouge, LA
    • Posts 563
    • Points 7,680
    how to use a 30 fps clip in a 24 fps project?
    i need to use a clip, shot at 30 fps, in a 24 fps project. what's the best way to do this?  thanks.
  • Thu, Jan 30 2020 11:15 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 554
    • Points 6,580
    Re: how to use a 30 fps clip in a 24 fps project?
    you get it into the project at the original 30 fps framerate.
    Avid will automatically apply timewarp on the clip if you cut it into the timeline.
    you can the edit the timewarp, turn it to 100% speed to play every frame without jitter. This will give you slight slow motion and youll loose sound-sync, but the picture is clear.
    if the picture needs to be sync with the sound, then you can only try different algorithms for the timewarp. Fluid motion might give very good results if you're lucky, depending on the picture.
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
