Latest post Mon, Dec 23 2019 5:33 PM by BarkinMadd. 8 replies.
Page 1 of 1 (9 items)
  • Thu, Dec 19 2019 2:41 PM
    • Rob
    • Joined on Thu, Nov 11 2010
    • NYC
    • Posts 125
    • Points 1,575
    Media Composer using all my Ram
    I'm running 2019.11 and after I upgraded I started to notice my computer was a lot slower within the program.
    In my task manger Avid is using all of my Ram (64gigs) . Not sure why, this never happend before.
    Does anyone know why it's doing this?
    MC 2020 HP Z8 / 192gb / NVIDIA Quadro RTX 6000 / Artist DNXiQ HP z820 / 64gb / NVIDIA M5000 MBPro / 64gb / Intel UHD Graphics 630 1536 MB [view my complete system specs]
  • Thu, Dec 19 2019 8:47 PM In reply to
    Re: Media Composer using all my Ram
    The numbers don't add up. THats  12 or 13 GB not 64GB
  • Thu, Dec 19 2019 9:44 PM In reply to
    • Rob
    • NYC
    • Posts 125
    • Points 1,575
    It's odd. When I close out of the program. The RAM goes down to 0. When I start it up, it uses all my RAM.
  • Fri, Dec 20 2019 3:21 PM In reply to
    • Posts 11,317
    • Points 232,510
    Rob,
    Go to task manager and see if Appmanhelper and Avidbackgroundservices are running and quit them and see if it changes
    M
  • Mon, Dec 23 2019 1:42 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,759
    • Points 62,055
    Also - check your media cache settings - you may have reserved too much memory there and it doesn't show up in task manager as being associated with the Media Composer application (or the background services).
    Steve
    ______________________
    www.nelliedogstudios.com
  • Mon, Dec 23 2019 2:19 PM In reply to
    • Rob
    • NYC
    • Posts 125
    • Points 1,575
    I went into Media Cache and set the Video Memory to 30gb and the file cache to 16.
    Still having the issue. I tried force closing the AvidOPFrameGeneratorApp.exe/AvidPhoneticIndexer.exe/AvidAppManHelper.exe
    And still the same problem.
  • Mon, Dec 23 2019 4:52 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,759
    • Points 62,055
    30gb is far too high - that could be your problem right there. Set it to 8 GB and the file cache to 4 GB and see how that plays out.
    Then if that works you can increase those numbers a bit.
    Good luck
    Steve
  • Mon, Dec 23 2019 5:28 PM In reply to
    • Rob
    • NYC
    • Posts 125
    • Points 1,575
    Hey,
    This worked. It took it RAM usage down to 30gb. Which is much better now.
    May I ask why taking it down reduces the amount of ram usuage?
    Thanks again for this!
  • Mon, Dec 23 2019 5:33 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,759
    • Points 62,055
    The media cache is EXTRA RAM that Media Composer can reserve from your total system memory and it uses this to cache video frames to speed-up playback. This memory is reserved in a special way that does not register as being consumed by the MediaComposer.exe application - it is in addition to all the memory already consumed by Media Composer (and all its related services).
    Steve
