Latest post Mon, Dec 9 2019 2:25 PM by LDV20. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Dec 3 2019 6:25 PM
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 303
    • Points 3,615
    Avid Link Wont Upgrade 2019.11
    Get an error a fle is missing  while upgrading from avid link.  So I went to  the download page but it seems stuck - nothing happens.     I knew I shouldnt have tried to upgrade.   So now I do not have the editing program
    Extremely furstrated
    Symphony 2020.8 - Win 10 pro (1909),Gigabyte X299X with i9 10920X cpu, Quadro P2000, 64gig memory, 1TB NV ystem drive, WD 4TB, BM Min Monitor, 11.7 drivers... [view my complete system specs]
  • Tue, Dec 3 2019 9:12 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,293
    • Points 25,295
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: Avid Link Wont Upgrade 2019.11
    Have you tried to download direct from My Avid.com? In Windows 10 you need to extract the zip file to the root directory for example C: newfolder to prevent corruption in extracting the file.
    RalphC
  • Tue, Dec 3 2019 9:52 PM In reply to
    • LDV20
    • Posts 303
    • Points 3,615
    I did  that - downloaded from download page - started to extract - now I am getting an errior Path too long
    Cam't believe this - avid link un installed 2019.9 - this is a mess
  • Tue, Dec 3 2019 10:03 PM In reply to
    • LDV20
    • Posts 303
    • Points 3,615
    it seems to download from your servers takes abnormal amount of time - I am trying to do another download
    I do not think it is my internet because everything else works fine - but the download center is extremely slow
  • Sun, Dec 8 2019 5:32 PM In reply to
    • willoswald
    • Posts 9
    • Points 115
    I had this both in the last two days and years ago. The simple fix is to move the entire install folder to the root directory when you unzip. Hope it helps.
  • Sun, Dec 8 2019 9:52 PM In reply to
    try using 7zip to extract the file from the download center.
    and extract at the root of the drive.
    that cleared up my problems with the 2019.11 file. Smile
  • Mon, Dec 9 2019 2:25 PM In reply to
    • LDV20
    • Posts 303
    • Points 3,615
    Thank you for your help - did that but it still did not work.  Called support they put in a different place and finally got it.  All ok
