Latest post Thu, Nov 14 2019 9:08 AM by Bruno M. 4 replies.
  • Wed, Nov 13 2019 6:28 PM
    • daktulus
    • Posts 960
    • Points 13,930
    MC 4.05 doesn´t start with analog Mojo
    MC 4.05
    I used to work with the combination MC 4 and my Mojo a lot many years ago.
    Now I need to digitize Hi8 tapes and need to use the combination MC 4.05 and analog Mojo again.
    But now, when starting MC, I get the error: "problem with hardware, power cycle your hardware." then MC quits.
    I power cycle Mojo and start again, but same error. I restarted the computer, but same error.
    Without Mojo I can run MC.
    i7, Nvidia 860M, 16GB RAM, 500GB SSD, MC 7.03. Dell Precision M90, Core2Duo 2.16Ghz, FX1500, SATA 7200rpm, MC 4.05. Dell650, 2.8Ghz, 3 GB RAM, FX500, 5... [view my complete system specs]
  • Wed, Nov 13 2019 6:49 PM In reply to
    Re: MC 4.05 doesn´t start with analog Mojo
    Has anything changed with the computer configuration? (OS update? drivers?)
    The Mojo connects via the IEEE1394 (FireWire400) port, maybe something has gone awry with your PCI 1394 card? Maybe try reseating it?
  • Wed, Nov 13 2019 8:58 PM In reply to
    I seem to remember changing the firewire driver to the legacy one.
    T 07581 201248 | E [email protected]
  • Thu, Nov 14 2019 12:37 AM In reply to
    • daktulus
    • Posts 960
    • Points 13,930
    Pat Horridge:
    What does that mean?
    Do I need to change my driver (which one?), because Avid changed something?
    When I used this Mojo with the exact same computer years ago, everything worked.
    I don´t think I changed a driver.
    Connecting a mini-DV camera directly to the computer works and the picture from the camera is seen in MCs capture.
  • Thu, Nov 14 2019 9:08 AM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 1,151
    • Points 14,600
    Pat Horridge:
    I remember having to do this with Windows 7/64 bit. If I also remember correctly, under Win XP, the firewire driver was fine.
    If you haven't changed anything, I wouldn't think it's the driver.
    It may be the Mojo that's at fault. Does it show up correctly in your Devices list?
    I see these pretty cheaply on Ebay occasionally, so maybe you could get a second Mojo to see if it's a hardware fault.
    HP Z800, HP G9 Fury, SonnetFusion RAID, Mojo DX, Decklink 4K, Ultrastudio 3G/4K, Symphony 2018 & 2023, Boland BVB25 OLED, JVC DTV1910 HD CRT, Eizo... [view my complete system specs]
