Can please AVID forum managers delete posts from before 2015 ? Are they really necessary ? Seriously ... they're a waste of time and are totally outdated . Thanks
keep on cutting
fss......... we dont delete anything. As there are SOME users who actually benefit from older articles as believe it or not, their are peeps still ysing older software.
To quote you... Seriously....... Why is it bothering you so much? When searching just dont go back that far. You can do advanced searching you know.
The data is valuable to some - so just go past it.
[email protected]
Marianna:The data is valuable to some
+1
+1, However, one thing I do believe is that the search engine needs to show results in order of newest thread/post on top.
(In general searching these forums has become a task only google has mastered.)
Avid reseller ACSR at Telmaco
http://www.telmaco.gr/en/
Agree with both points. Googling works so much better than the forum search for some reason.
Jeroen van Eekeres:I do believe is that the search engine needs to show results in order of newest thread/post on top.
Alayne
Point is that it should be the default setting imho.
Marianna: fss......... we dont delete anything. As there are SOME users who actually benefit from older articles as believe it or not, their are peeps still ysing older software. To quote you... Seriously....... Why is it bothering you so much? When searching just dont go back that far. You can do advanced searching you know. The data is valuable to some - so just go past it. Marianna
Another +1 for me please.
I find the old information really useful!
Sometimes they can be quite handy because some issue might return with a newer version or (more likely) the same fix for some old issue still holds true in the newer versions.
