Another random error we're getting across all suites since installing 2019.9
Sometimes on exporting a timeline to MXF OP1a, timeline is marked in/out, the error comes up after clicking save to export the file, but if you then refresh the marked in/out and try again the export works fine.
AntCaladine: Another random error we're getting across all suites since installing 2019.9 Sometimes on exporting a timeline to MXF OP1a, timeline is marked in/out, the error comes up after clicking save to export the file, but if you then refresh the marked in/out and try again the export works fine.
Hey Ant.....
This error message indicates corruption in the sequence. The first step to take is to divide and conquer the sequence to find out what could be corrupt.
Corruption occurs when a file's data has been miswritten and the file cannot be read correctly by MC
To find out more information about corruption. Finding Corruption in the Editor......
http://avid.force.com/pkb/articles/en_US/Troubleshooting/en268209
Weiredly it didnt do it on this project on the previous version we had instaledl (2019.7) Only since updating.And why would clearing the in/out and redoing the same would it export if there was a corrupt clip?
Ant,
No idea unless the corruption occured when the project was being opened on the newer version. Hard to tell though.
I've found the problem. Lets see if you/tech can recreate.Project is 1080p/59.94Occasionally when you select full in/out (T on keyboard) it places an outpoint outside the end of the timeline.If you remove and create manually its ok
Ant....
Let me try this..........
