Latest post Tue, Oct 22 2019 5:35 PM by curiosity. 4 replies.
  • Tue, Oct 22 2019 5:05 AM
    • curiosity
    • Boulder, CO
    • Posts 836
    • Points 10,565
    Installer background image casues stall
    Anyone else noticing this?
    When I open an intsall dmg file (on Macintosh) the installer app icons show up and then I get a rainbow wheel for about 5 minutes while it does something (processes?) the background image of the installer.
    To be fair this isn't just an Avid thing, it seems to be doing this with a bunch of dmg installers, its just Avid's rainbow wheel is about 10x longer than any other installer.
    I have this problem on all 40 systems I manage including:
    • 2012, 2016, 2018 iMacs
    • 2016, 2018 Mac Pro
    • 2012, 2016, 2019 Macbook Pro
    Under everything from:
    • El Capitan (10.11) - Mojave (10.14)
    Most configured with
    • 32GB RAM
    • 2TB Hard Drive (Some Fusion some non)
    i7-5820(x99), 64GB, Win 8.1, GTX 1080ti [view my complete system specs]
  • Tue, Oct 22 2019 1:54 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,157
    • Points 24,015
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: Installer background image casues stall
    Can you try In finder, launch /System/Library/CoreServices/Installer.app. It will prompt you to locate a .pkg file to install. Navigate to the .dmg volume you've mounted, and select the AvidMediaComposer.pkg file.
  • Tue, Oct 22 2019 2:39 PM In reply to
    • jcmcnamee
    • Brooklyn, NY
    • Posts 280
    • Points 2,965
    I can't remember the last time this DIDN'T happen for me (pre 2018.12?). I've learned to just open the dmg and let it do its thing in the background until the image finally shows up and I can install. But I'm only managing one system...can't imagine going through this on 40!
    Media Composer 2020.6 / OS 10.15.5 27" iMac 5K 2017 [4.2 GHz Intel Core i7, 64 GB ram, Radeon Pro 580 8 GB] [view my complete system specs]
  • Tue, Oct 22 2019 4:37 PM In reply to
    • curiosity
    • Boulder, CO
    • Posts 836
    • Points 10,565
    RalphC:
    Can you try In finder, launch /System/Library/CoreServices/Installer.app. ...
    Ahhh. That's a good way to get around this. Thank you.
    It would be nice if it worked though...
  • Tue, Oct 22 2019 5:35 PM In reply to
    • curiosity
    • Boulder, CO
    • Posts 836
    • Points 10,565
    Hmmm. The problem I have is how to mount the dmg without openeing the the Finder window. I tried:
    hdiutil attach -nobrowse <path to dmg>
    But I have the same problem, it gets stuck on a LOOOOOONG "Checksumming disk Image" process, and while this eventually works - it mounts the dmg in /Volumes/ but doesn't provide a GUI mountpoint. So I have to launch the installer from the command line:
    sudo installer -pkg <path to pkg> -target <path to target>
    All of which just to get it to install the application in less than 15 minutes of waiting per system....
    There has to be a better way.
