Latest post Thu, Dec 5 2019 4:55 PM by matev. 2 replies.
  • Thu, Sep 26 2019 2:05 PM
    • matev
    • Joined on Tue, Aug 2 2016
    • Posts 15
    • Points 175
    Limitations of payloads' size for POST requests via upstream
    Hi All,
    we are having problems invoking our custom service connected to the cloud ux bus (v2019.6) with bigger payloads. We are using standard http.post calls from the cloudux ui with an application/json content. If we post a request with payload containing around 30 000+ chars, then the request recevies timeout from upstrem.
    Is there really a limitation on the payload size or the problem is elsewhere?
  • Mon, Nov 11 2019 1:37 PM In reply to
    Re: Limitations of payloads' size for POST requests via upstream
    Hi matev,
    Can you attach logs from this request to specify which timeout you had?
    Upstream doesn`t have limit in this case.
    The reason might be incorrect ingress configuration, parsing message issue, bus timeout or size limit from another service. Could you provide logs or an error code to tell more about this issue?
    TY/Vlad.
  • Thu, Dec 5 2019 4:55 PM In reply to
    • matev
    • Posts 15
    • Points 175
    Hi Vladyslav,
    it was a standard upstream timeout after 10 secs like this:
        "code""avid.upstream/SERVICE_QUERY_TIMEOUT",     "params": {},     "message""Query timed out",     "incident""624c6280-177f-11ea-b27c-9aaf44f0a7ca",     "exchange""5c30aa01-177f-11ea-b27c-9aaf44f0a7ca",     "status"504 } But it seems Cloud UX v2019.9.2 does not have this problem :) Thanks
