Latest post Mon, Sep 30 2019 9:57 AM by MykeWOC. 2 replies.
  • Fri, Sep 20 2019 11:54 AM
    • MykeWOC
    • Joined on Tue, May 28 2019
    • Posts 2
    • Points 20
    Cannot delete master clips in bin
    I am having issues deleting master clips in bins. The clips and bins are not locked. I am able to delete bins and folders in the bin container so it isn't the keyboard.
    This doesn't seem to be a known issue as it is not in the known issues 2019.8.pdf
    Any suggestions?
    Media Composer: 2019.8.0 iMac Pro (2017) macOS Mojave 10.14.6 3 GHz Intel Xeon W 128 GB 2666 MHz DDR4 Radeon Pro Vega 64X 16GB [view my complete system specs]
  • Tue, Sep 24 2019 4:11 PM In reply to
    Re: Cannot delete master clips in bin
    Are you trying to press the delete key?
    What happens when right-click and select Delete?
  • Mon, Sep 30 2019 9:57 AM In reply to
    • MykeWOC
    • Posts 2
    • Points 20
    Yes, I've pressed the both delete keys on the keyboard and also from the edit menu.
    I suspect the issue is related to my user profile since I've temporarily resolved it by switching to a new user profile and then cycling back. After cycling, the delete keys and edit menu function worked normally. Thanks for your help.
    <!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:0; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:3 0 0 0 1 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-536859905 -1073732485 9 0 511 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Calibri",sans-serif; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;} p {mso-style-noshow:yes; mso-style-priority:99; mso-margin-top-alt:auto; margin-right:0cm; mso-margin-bottom-alt:auto; margin-left:0cm; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman",serif; mso-fareast-font-family:"Times New Roman";} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; font-family:"Calibri",sans-serif; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;} @page WordSection1 {size:612.0pt 792.0pt; margin:72.0pt 72.0pt 72.0pt 72.0pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.WordSection1 {page:WordSection1;} -->
