Hey all-
Does anyone know if it's possible to reduce the amount of lead time that the playhead will give when you push spacebar and an edit is selected?
For fine-tuning edits I can make a trim on a clip, and then push spacebar, it jumps back a full two seconds. Most of the time I would prefer just half a second or less. Is it possible to change the default value here?
Matt
chapmattman: Hey all- Does anyone know if it's possible to reduce the amount of lead time that the playhead will give when you push spacebar and an edit is selected? For fine-tuning edits I can make a trim on a clip, and then push spacebar, it jumps back a full two seconds. Most of the time I would prefer just half a second or less. Is it possible to change the default value here? Thanks Matt
Its in the trim settings. you can set it to whatver you want and set the post roll as well.
