Latest post Fri, Sep 20 2019 3:29 PM by Isaac T.. 2 replies.
  • Thu, Sep 19 2019 12:49 AM
    • Nick Link
    • Joined on Thu, Aug 16 2012
    • Miami, FL
    • Posts 38
    • Points 460
    Connecting two Avids... should I?
    Hey All,
    Today I moved my “office” Avid to my house, where I’ve already been set up with my “home” Avid. The specs on each are listed below but basically the I’ve got a 2017 iMac running MC 2019.7 and bringing in a MacPro 2010 8core tower running MC 8.6.
    Question is, what’s the best way to network them together, maybe using the 8core for rendering and transcoding, and the iMac as the main editing box? Ethernet I’d assume? Or should I even bother connecting them? I know the new software offers Distributed Processing for just this kind of thing, I think... or it probably requires Nexis? Can someone point me to more info on that?
    I’m anxious to run some tests in the next couple days to see if, and by how much, the MacPro is faster than the iMac. Or maybe it’s not.
    Anyone ever mess around with such a setup? Maybe it’s a fools errand and I should just sell off one of them.
    Appreciate any thoughts.
    Nick
    HOME AVID: iMac 27" (Retine 5K 2017) 3.4 Intel i5 / Mojave 10.14.16 / 40GB RAM / Radeon Pro 570 4GB / MC 2019.7 WORK AVID: MacPro (Mid2010) 8core... [view my complete system specs]
  • Thu, Sep 19 2019 4:56 PM In reply to
    • Leo Baker
    • Joined on Wed, Oct 5 2011
    • Posts 493
    • Points 5,790
    Re: Connecting two Avids... should I?
    Hello Nick,
    You can connect through Ethernet cable if you want to netwotk this shating the files back and forth between the two Mac computers. I do that with teo computrs through Ethernet it works very well rather then swapping drives between two computers.
    Distributed Processing needs the Nexis to give that feature I read. Also the additional software for Distributed Processing not sure if it's included etc with Nexis or a paid add on.
    Leo
    MacPro6.1 Late 2013 Intel Xeon 12-Core 2.7GHz 64GB RAM AMD FirePro D700 6GB OSX Mojave 10.14.6. Media Composer 2020.5, Pro Tools Ultimate 2020.5, Avid... [view my complete system specs]
  • Fri, Sep 20 2019 3:29 PM In reply to
    • Isaac T.
    • Joined on Mon, Jan 9 2006
    • New York / Knoxville, TN
    • Posts 759
    • Points 8,960
    @Nick Link:
    This section of Frame.io's WORKFLOW Guide should be helpful too:
    Chapter 3: EDIT -> Shared Storage: https://workflow.frame.io/guide#ch=edit&s=shared-storage
    Some of the deep dives focus specifically on Media Composer in a multi-workstation environment.
    In answer to a couple items:
    1. That Mac Pro should be helpful as a dedicated transcoder, but that iMac will probably be faster (more cores, faster clock speed).
    2. While transcoding, launch Activity Monitor, then go to Window -> CPU Usage. Observe and compare how MC uses your CPU cores during transcoding.
    3. If you're weighing out a Shared Storage option, I can't recommend the Lumaforge Jellyfish enough (https://lumaforge.com/index.php?p=jellyfish). They cracked the code.
    Mid-2010 Mac Pro • 2018 MacBook Pro [view my complete system specs]
    isaact.co | Twitter | Instagram | Vimeo
    Writer: The Frame.io WORKFLOW Guide - http://workflow.frame.io/
    Post Workflow Consultant - https://isaact.co/
