Latest post Fri, Sep 6 2019 10:10 AM by pierreh. 3 replies.
  • Thu, Aug 8 2019 5:13 PM
    • Posts 11,323
    • Points 232,540
    Media Composer 2018.12.7 Available 8.8.19
    Media Composer 2018.12.7 Avialable 8.8.19
    As part of Avid’s Long Term Maintenance Release commitment, Media Composer 2018.12.7 launched today, Thursday August 8. 2019.
    Location at Launch: The Updates to Media Composer 2018.12.7 ( Mac and Win ) is available from the Avid Download Center (login and password required) only. The Download Center is accessible via the MyAvid Master Account.
    Status of Support Plan:  The ability to launch this Media Composer 2018.12.7 software is dependent on the status of your Upgrade and Support Plan on the date this software version is released.
    Changed in Media Composer 2018.12.7:  The following has changed with this release.
     -  Simplified Installer - A change has been made to the Installer to remove an install menu window. When you download Media Composer v2018.12.7, simply double-click Install Media Composer.exe to install Media Composer.
    -  Open I/O NDI Plug-In - In previous releases, the Open NDI Plug-In was automatically installed when you installed Media Composer.  With this release, you have the option to install or not during the install process.  For details on this plug-in, see “Support for NewTek NDI Video over IP” in the Media Composer Help.
    Fixes:  there are a lot of fixes in this release.   See attached ReadMe
    Enjoy all of you on the old UI.
  • Wed, Aug 14 2019 7:32 AM In reply to
    • derDoyle
    • Joined on Tue, Aug 18 2015
    • Berlin, Germany
    • Posts 136
    • Points 1,645
    Re: Media Composer 2018.12.7 Available 8.8.19
    Hello,
    it seems to be that
      Bug Number: MCCET-3004. In the previous release, you could not use the patch installer if you were using a non-English locale.
    is not fixed with the new Open I/O NDI Plug-In Installer.
    I have some german friends on PC wich are getting an error. It roughly translates to
    The help string Open I/O NDI for the DlgTitle control in the EnterpriseAdminConfig dialog box does not contain a delimiter.
    I seems to be affecting the Full Installer also.
    I can't reproduce this on Mac but I thought I just pass on the information.
    Doyle
    Clients: MacPro6.1 (2013 "Trashcan"), 3,5GHz 6-Core, 16GB (1866) RAM, AMD FirePro D500, 256GB SSD, macOS 10.14.6, Avid MediaComposer 2018.12... [view my complete system specs]
    Passionate In-House Avid Support
    Admin of the German Avid Community on Facebook
  • Sun, Aug 25 2019 4:40 AM In reply to
    This has happened to me before with an upgrade, and again is happening with 2019.7
    When I import an AAF with closed captioning data, the data media shows "offline".   I've noticed this when a major upgrade has happened before.  Is this a bug experienced by anyone else?
    Thanks so much.
    Ernie Nathaniel
  • Fri, Sep 6 2019 10:10 AM In reply to
    • pierreh
    • Paris, London
    • Posts 1,269
    • Points 15,355
    We're still on 2018.5 as most versions after that added more bugs than fixes. Is there a general consensus on this latest version?
    - Work: MacPro 2010 3.46Ghz 12 Cores 48Gig RAM, Mojo DX, 10.14.6 - Home: MacBookPro 2.5Ghz quad-i7, 16Gig Mem and SSD OSX 10.11.6 [view my complete system specs]
