Latest post Thu, Aug 22 2019 6:04 PM by RalphC. 20 replies.
  • Tue, Jul 23 2019 5:04 PM
    • Adman
    • Atlanta Georgia, USA
    • Posts 5,432
    • Points 61,250
    • BlogAuthor
      Moderator: Avid Free DV
      Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
    Media Composer 2019.7 available now...
    Great News!  The new Media Composer 2019.7 release along with Media Composer | First 2019.7 is now available.
     Updates to Media Composer available from Avid Link, MyAvid and the Avid Download Center (login and password required).
     Dongle Info (Mac Only): If you have a dongle, the dongle Sentinel driver installer is no longer automatically installed when you install the editing application. The driver is now located in the Avid_Utilities folder. If you have a dongle, manually install the driver from this location (/Applications/Utilities/Avid_Utilities/Sentinel_Driver).
     Status of Support Plan:  The ability to launch this Media Composer 2019.7 software is dependent on the status of your Upgrade and Support Plan on the date this software version is released.
     What’s fixed in 2019.7:  The following have been fixed:
     -  Bug Number: MCCET-2905. Using the arrow up and arrow down keys to move clips from one track to another did not work when a nested effect was open.
    -  Bug Number: MCCET-3016. Audio meters did not display in the Audio Tool, Audio Mixer or Timeline window during a Digital Cut.
    -  Bug Number: MCCET-2986. In some instances, adjusting audio level from the Audio Mixer, while playing a sequence, did not affect the volume.
    -  Bug Number: MCCET-3006. (Windows) Media Composer would crash when importing embedded AAF into a 25fps HD project.
    -  Bug Number: MCCET-3112. (Script View) In some instances, Media Composer would crash when scrolling in a large bin and while playing in the Source/Record monitor.
    -  Bug Number: MCCET-3003. You could not rename group clip tracks.
    -  Bug Number: MCCET-2899. All related media object where not highlighted when selecting media relatives if you grouped clips and selected Select Sync Clips Using “Film TC/Sound TC”.
    -  Bug Number: MCCET-3031. In some instances, when I/O hardware was enabled, you could not import/transcode to AVCIntra50.
    -  Bug Number: MCCET-3036. When working with an HD 1080p 25 project, transcode options changed if I/O hardware was enabled/disabled.
    -  Bug Number: MCCET-3032. You might have received an “Exception: No Source” error when performing a video mixdown and choosing over/under as a Stereoscopic option.
    -  Bug Number: MCCET-3086. You could not copy and paste markers using Ctrl + C and Ctrl + V.
    -  Bug Number: MCCET-3059. You could not save newly created and renamed shared bins in project sub folders.
    -  Bug Number: MCCET-3041. If you pressed ESC a few seconds after performing a trim, the Timeline did not update correctly.
    -  Bug Number: MCCET-3026. When consolidating a subclip with “Delete original media files when done” enabled, an unrelated Transcode notification message was displayed.
    -  Bug Number: MCCET-3073. AAF exports did not include the media if the clip was muted.
    -  Bug Number: ETE-1512. A dark gray fill (instead of black) is provided now in the viewer for Pillar and Letter box areas that are not masked.
    -  Bug Number: MCDEV-11146. Removed Show Position and Show Effect Contents from the Timeline settings.
    -  Bug Number: MCDEV-8227. When switching between MXF and OMF media types in the Media Creation window, the window would not refresh until it was reopened.
    -  Bug Number: MCDEV-8527. The Tool Palette moved position after resizing.
    -  Bug Number: MCDEV-10060. Precomputes were lost when reentering the Avid Titler+Title tool.
    -  Bug Number: MCDEV-10346. An asterisk might have appeared in the Bin name even if no changes had been made to the bin.
    -  Bug Number: MCDEV-10412. You might have experienced problems loading sequences with Avid Titler+ titles between Windows and Mac systems.
    -  Bug Number: MCDEV-10512. Avid Titler+ characters did not maintain relative position between each other during animation playback.
    -  Bug Number: MCDEV-10624. Scrolling in Text view in a bin was column by column rather than by pixel.
    -  Bug Number: MCDEV-10632. Even when a change was made, the Bin View name did not display in italics to indicate a change to the view had been made.
    -  Bug Number: MCDEV-10801. Changing the sequence name in Frame View did not update the name in the Composer monitor or in the Timeline.
    -  Bug Number: MCDEV-10818. Floating a bin might have resulted in the bin resizing too small.
    -  Bug Number: MCDEV-10880. When creating a Volume Bin, “Export Folder” and “Set location” text does not display correctly if you are working in a Russian locale.
    -  Bug Number: MCDEV-10918. Mapping “Set Bin Display” to a letter on the keyboard did not work.
    -  Bug Number: MCDEV-10934. Typing the first letter of setting displayed the setting at the bottom of the window rather than in the middle of the window.
    -  Bug Number: MCDEV-10995. When in Frame view, if you dragged a clip to the Source Monitor, the clip would load into the source monitor, but the clip’s thumbnail was moved to an unintended location within the bin.
    -  Bug Number: MCDEV-11131. In some instances, effects with graphic backgrounds did not draw correctly in the track effect dialog.
    -  Bug Number: MCDEV-11145. An Interlaced Roll/Crawl motion effect created with Titler + appeared as a frame motion rather than field motion effect.
    -  Bug Number: MCDEV-11191. Double clicking to float an existing bin always stacked the bin in same position/size and did not retain its last known state.
    -  Bug Number: MCDEV-11231. You might have experienced an occasional crash on exit with AJA 4K hardware attached. You must update to AJA Desktop software v15.2 to see this fix.
    -  Bug Number: MCDEV-11245. The File Cache tab in Media Cache Settings window was cut off and difficult to activate.
    -  Bug Number: MCDEV-11299. The font appeared bold in the Name fields for the Source and Record side of the Composer window.
    -  Bug Number: MCDEV-11317. Titler + titles appeared in the bin without an icon.
    -  Bug Number: MCDEV-11429. The Name column did not appear as the first column in the Media Tool.
    -  Bug Number: MCDEV-11442. (Bin Frame view) Clicking near edge of a selected item in the bin while in text-edit mode deselected the item.
    -  Bug Number: MCDEV-11453. The Audio Clip Gain window did not remain open when you tried to enter a value from the keyboard or if you tried to move the slider up with the mouse.
    -  Bug Number: MCDEV-11491. Pressing and holding the ALT key while dragging a number of clips onto the Record monitor did not create a sequence with the clips in the order they were sorted in the bin.
    -  Bug Number: MCDEV-11492. If you selected a dropdown menu in the Inspector Tool and then clicked on another window, focus remained on the Inspector Tool.
    -  Bug Number: MCDEV-11530. Double clicking a clip in Bin Frame view to load in the Composer monitor did not leave focus on the Composer monitor.
    -  Bug Number: MCDEV-11534. The Lock/Unlock Bin options were missing from the Bin Container sidebar context and Fast menus.
    -  Bug Number: MCDEV-11546. You might have received a “Crumb not found” error when deleting markers in the Source monitor.
    -  Bug Number: MCDEV-11550. Perf information was missing in the Setting format pane of a film project.
    -  Bug Number: MCDEV-11562. Tab and Shift+Tab did not allow you to move to the next or previous column in Bin Text View.
    -  Bug Number: MCDEV-11568. With the Interface Brightness set to dark, track numbers were too light when you expanded the Audio Mixer Tool.
    -  Bug Number: MCDEV-11569. You might have received a “PMM_SYNC_FAILURE” error when performing an Audio mixdown of a sequence with sub-clips and sample slip.
    Limitations Media Composer 2019.7:  Listed below are the known limitations in v2019.7.
    -  Bug Number:  If you launch a project and receive an “Enable 3rd Party Emulation” warning, even if you select Enable in the warning dialog, you should also perform the following: Select File > Settings and click the Project tab. Click General Settings and select “Enable Bin Sharing on 3rd party storage emulating Avid NEXIS/ISIS.”
    -  Bug Number: MCDEV-11197. In some instances, the Interleave option might not appear in the Export As dialog box. If you are performing an Export using the Avid Media Processor, the Interleave option should appear when you choose Stereo, 5:1, or 7.1 Audio.  Workaround: If it does not appear, briefly toggle back to the Mono setting, then toggle to Stereo Mix once again. Doing so should reveal the Interleave option.
    Bug Number: MCDEV-8641. (AMD Graphics). Systems with AMD graphics cards might display tearing when performing Full Screen playback.
    -  Bug Number: MCDEV-9460. Windows 7 systems with Nvidia Maxwell or Nvidia Pascal cards might experience playback issues that could result in “Play Consumer timeout” errors. Workaround: Select “Disable GPU Effects” in the Render Settings dialog box.
    Bug Number: MCDEV-9269. (Media Composer | Cloud) After performing a remote download operation on a sequence containing AVC-I 100 remote media, the downloaded media appears as XAVC-I 100. Workaround: Download the entire master clips.
    Bug Number: (Mac). You may occasionally see the menu bar flash followed by a brief beach ball. To fix this, deactivate “Displays have separate spaces” under System Preferences > Mission Control settings.
    Bug Number: MCDEV-9011. Intermittently, when working with the XDCAM Nablet Plug-in, you might see “Failed to get the sample position from the AMA Plug-in” errors if you have waveforms enabled in the Timeline.
    -  Bug Number: COGS-2560. While working in the Script Window, text operations (cut/copy/paste/delete/editing) can only be done in edit mode. See “Editing a Script” in the Help.
    -  Bug Number: MCDEV-5650. When working with Panasonic LongG media, you might receive an “SFPlayConsumer Timeout” error if audio waveforms are enabled. Workaround: Turn off audio waveforms. 9
    Bug Number: MCDEV-5385. MultiCam editing with Panasonic LongG media is not supported with this release.
    Media Composer 2019.6 Documentation: The “ReadMe” document for this release of Media Composer 2019.7  has been uploaded to the Knowledge Base - Media Composer 2019 Documentation Page
    How to obtain the Media Composer 2019.7 Update: The new Media Composer 2019.7 has been made available too:
    1.  Customers who have an active support and upgrade plan will be notified of the availability of the 2019.7 via Avid Link and it will be available via Link, MyAvid and the Download Center.
    2.  New perpetual and subscription Licenses purchased on or after today, Tuesday, July 23rd, 2019 will also receive 2019.7.
    Mac Pro, 64GB Ram. 1TB SSD system drive, 250Gb SSD external (media) drive. QHD Ultra wide, thunderbolt LG monitor, MC 2019.12.1. Pro Tools 11 HD (Mbox... [view my complete system specs]
  • Tue, Jul 23 2019 8:55 PM In reply to
    • rodpaul
    • Posts 103
    • Points 1,390
    Re: Media Composer 2019.7 available now...
    Getting fatal error message from Baselight followed by fatal error from Media Composer. restarts etc. no help. Having to roll back to 2019.6.
    Dell T3600T 12 Cores 3.5 ghz Intel 32GRAM K4200 Windows 10 [view my complete system specs]
  • Wed, Jul 24 2019 12:29 PM In reply to
    • Posts 11,316
    • Points 232,495
    rodpaul:
    Rodpaul
    Baselight has a bunch of new licenses so I would reach out to them and see if they are having any issues with 2019.7.
  • Wed, Jul 24 2019 5:01 PM In reply to
    • rodpaul
    • Posts 103
    • Points 1,390
    Already done.
    I can't find 2019.6 on the download page, and don't still have 2019.6 on my computer. Where can I get it so I can roll back to a version that works with Basselight?
  • Wed, Jul 24 2019 5:26 PM In reply to
    • Posts 11,316
    • Points 232,495
    2019.6 is there at the very bottom of the Media Composer Folder on the Download Center.
    http://esd.avid.com/ProductDownload.aspx?id=2200
  • Wed, Jul 24 2019 5:44 PM In reply to
    • rodpaul
    • Posts 103
    • Points 1,390
    Thanks! Found it -
  • Fri, Jul 26 2019 8:28 AM In reply to
    • benholden
    • Joined on Mon, Apr 13 2015
    • London, UK
    • Posts 39
    • Points 480
    Hi Marianna, sorry to post in the PC side of the forum, and if this has been, or is due to be posted, my apologises, but was wondering if MC updates can be posted to the MC Mac forum. Of late I have started to notice that new MC release/patches info/links etc (as per this post) have been lacking on the MC Mac forum. I reguarly look through both the MC PC and Mac forum, so able to read the release notes etc., but would be great if the posts could also been seen within the Mac forum.
    Avid MC v2019.9 / Mojo DX / Mac Pro 6.1 late 2013 / MacOS 10.12.6 / 64GB Memory / AMD FirePro D500 / 3GHz 8 Core Intel Xeon E5 / LG 34UC98 Ultra Wide Display... [view my complete system specs]
  • Fri, Jul 26 2019 12:46 PM In reply to
    • Posts 11,316
    • Points 232,495
    benholden:
    Ben
    They should be posted to both.... looks like a few Mac moderators are snoozing on the job so I need to get them back in line :)
    I will address it and thanks for letting me know.
  • Fri, Jul 26 2019 3:58 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,756
    • Points 62,020
    Marianna:
    rodpaul:
    Rodpaul
    Just tried MC 2019.7 with Baselight 5.2 (the latest build) and no problems (UHDp29.97 project).
    Steve
    ______________________
    www.nelliedogstudios.com
  • Fri, Jul 26 2019 4:05 PM In reply to
    • Posts 11,316
    • Points 232,495
    BarkinMadd:
    Woot woot - thanks Barkin.....  Excellent!!!!!
  • Sat, Jul 27 2019 9:59 AM In reply to
    • dew
    • Joined on Tue, Feb 27 2007
    • Posts 593
    • Points 7,525
    Just want to make sure. This is a full install, so I have to uninstall 2016.6 first?
  • Sat, Jul 27 2019 10:08 AM In reply to
    dew:
    2019.7 is a full install. Normally I just run the installer and let it do whatever it wants to do with the previous installation. Strangely, 2019.7 told me I'd need to uninstall the previous version of MC using Windows Add/Remove Programs. I did, and 2019.7 installed fine afterward.
    To be extra safe, I renamed Avid Users, Avid Projects, and Avid MediaFiles to keep them from being removed during the installation. I don't think this was necessary, but I didn't feel like having to restore anything from a backup version.
  • Mon, Jul 29 2019 8:35 AM In reply to
    • benholden
    • London, UK
    • Posts 39
    • Points 480
    Marianna:
    benholden:
    Ben
    Thanks Marianne, much apreciated. (p.s. as of responding Monday morning, still no 'offical' Avid moderators post on the Mac forum Yes)
  • Mon, Jul 29 2019 2:55 PM In reply to
    • WAIF2318
    • Joined on Tue, Nov 15 2011
    • Posts 334
    • Points 4,155
    hi,
    How to add the overwrite trim and Ripple trim selection buttons like that in version 2019.6 in front of the timeline of version 2019.7
  • Wed, Jul 31 2019 11:38 AM In reply to
    • WAIF2318
    • Posts 334
    • Points 4,155
    I went back to the familiar interface 2018.12.6, and the interface version 2019.7 was really uncomfortable...
